Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Platinum Member tmarks11's Avatar
    Join Date
    May 2005
    Posts
    918
    Seattle, WA
    Power Trac 422 (2005)
    Default Re: Circulating Pump / Heater
    I think Mossroad is on to something. You have to heat up the engine compartment to help with the engine start, not the hydraulic tank.
    I aim my 5000W 220V space heater in the back end of the engine compartment (not close enough so stuff melts), and let that sit for an hour. Seems to make a big difference. Little 1500W heaters are useless when the garage is at 20F.
    Tim
    2005 PT-422
    4n1, LMB, minihoe, 48" mower, brush hog, Land Pride aerator, Herd spreader, auger, towing, forks, box blade, plow, box blade, tiller, trencher
    PT422 (6/23/05) photo page
  2. #12
    Gold Member
    Join Date
    Jul 2011
    Posts
    349
    Power Trac PT-422
    I agree with you MossRoad. Would love to be able to get the engine running, or at least know what the problem is with out sinking a boat load of money into it.
    Terry told me last week the Robin is a great engine, however it is one of the worst when it comes to cold starting. Aren't there other brand engines that are good engines which start in cold weather climates without going to extremes.
  3. #13
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,207
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Hit your local thrift store and get couple of big heavy blankets, then use them, a $20 electric "milkhouse" heater (we have this one and it works well) and possibly a couple pieces of plywood to get things toasty warm (build an insulated "doghouse" around the engine/pump area and let the heater run till everything is toasty warm). Then try starting it.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  4. #14
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,816
    West Cascades, Washington State USA
    PT 422
    Quote Originally Posted by aczlan View Post
    Aaron Z
    seems like this would be doable. I picked up one of those heaters at a thrift shop too, about two dollars, now it's in the well house.
  5. #15
    Join Date
    Mar 2007
    Posts
    1,533
    Bay Area, CA
    Power Trac PT1445
    Ummmm....
    If you are getting a space heater near gasoline, you want to be really, really careful.
    In general, the ceramic heaters are considered safer because the heating element is at a lower temperature compared with the milk house heaters. In all cases, you want to be concerned about a thermostat or switch that might arc.
    Personally, I would stick with the magnetic heaters or the space heaters at a distance. I would point out that most of the oil recirculates in the drive circuit, so even if the pump and/or hydraulic tank is warm, as soon as the oil goes out to the wheel motors, it will get cold until the drive circuit warms up.
    As an aside, the hydraulic pumps and motors have very tight tolerances and are designed to work at a constant temperature. TBased on my limited understanding, I think that the way that we use them is decidedly off label. Once a PT is started in the cold, I would give it a chance to warm up throughout before pushing it. I think MR's method of starting the PT and then letting it idle while he shovels is a great idea for longevity.
    Oh, another vote for getting the engine taken care of first. :-)
    All the best,
    Peter
  6. #16
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,810
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    I took a video about two weeks ago of me starting my 12year old 2001 PT425 Kohler command engine with 500ish hours and the original spark plugs at 9 degrees in my garage. (Its too big to post here, but I'll figure something out eventually) Anyhow, I didn't use any starting fluid nor did I put it on the battery charger for the past two months. Had I had two hands free to operate the throttle and choke, it would have started in about 5 seconds. However, I was trying to hold the iPhone with one hand and it was not possible to manipulate the throttle and key at the same time. Once I put the camera down and used two hands it fired right up.
    Could it be something as simple as the starter motor on the Robin is too weak to turn the engine fast enough when it is pushing cold hydraulic fluid?
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  7. #17
    Join Date
    Aug 2001
    Posts
    33,810
    Has anyone tried using a booster battery with jumper cables on the Robin equipped PT to see if they can get some more amps behind the starter?
    MossRoad
    Of It In Action!!!
  8. #18
    New Member
    Join Date
    Jan 2010
    Posts
    8
    I use an old hair dryer. I put a shop vac extension on it maybe two foot long ,three or four inch dia. I kind of latch it onto the hydraulic pump or aim it at the pump,shut the hood on it and throw an old blanket over the dog house cover. Let it run for about twenty minutes or untill the pump feels warm. starts up every time.pt 180 robin 18hp.
  9. #19
    Join Date
    May 2005
    Posts
    918
    Seattle, WA
    Quote Originally Posted by MossRoad View Post
    Robin put a bigger starter motor on their engines starting about 4 years ago. The PT in question undoubtedly predates that. I have the old starter motor on mine.
    So yes, that could be part of it.
    Quote Originally Posted by ponytug View Post
    Not too worried about fuel vapors in 20-30F weather. I use the space heater all the time. Works way better now that I have a 5600W 220V version (insert Tim the Toolman grunt). With the gas cap on the tank, nothing is going to happen.
    Circulating Pump / Heater-heater-jpg
    Obviously keep it at least a foot away; don't want to melt anything.
    Tim
    2005 PT-422
  10. #20
    Join Date
    Aug 2001
    Posts
    33,810
    Quote Originally Posted by dchapman View Post
    We used to do something similar with airplane engines only it was a propane burner. But no reason it wouldn't work. Just make sure the hose is able to take the temps and won't burst into flames and light the blanket on fire.
    MossRoad
    Of It In Action!!!
Similar Threads
  1. Engine block heater / coolant heater & high-capacity alternator
    By Phunge in forum John Deere Owning/Operating
    Last Post: 02-04-2015, 03:19 PM
  2. TC30 Block Heater stupid questions and Transmission Heater advice
    By ksshooter in forum New Holland Owning/Operating
    Last Post: 10-28-2011, 05:01 PM
  3. Replies: 17
    Last Post: 09-24-2009, 10:56 PM
  4. GC2300/GC2310: block heater or recirculating antifreeze heater?
    By FredWalter in forum Massey Ferguson Owning/Operating
    Last Post: 02-28-2008, 04:13 PM
  5. repalced water pump- heater not working now?
    By goaliedad in forum Related Topics
    Last Post: 10-15-2007, 09:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
