Results 1 to 6 of 6
02-23-2013, 12:50 PM #1Bronze Member
- Join Date
- Jul 2011
- Posts
- 73
- Tractor
- Steiner 430
Steiner / Ventrac attachments quick plate?
Was wondering if any Power Trac owner has ever made a quick attach plate that adapts to Steiner and Ventrac attachments, or if it is even possible.
02-23-2013, 05:02 PM #2
Re: Steiner / Ventrac attachments quick plate?
I had my Steiner tractor stolen and was left with my leaf blower. I converted it to a quick attach plate by cutting off the steiner stuff. I pulled off the pulley and replaced with a hydraulic motor. Steiner and Ventrac stuff is all (belt) pulley powered while Power trac is hydraulic so unless you have something that don't need to be powered by a belt it could work ok. I always wondered what if the mower deck could be converted to a hydraulic system if it would work well or be to underpowered for a side discharge. What attachments are you thinking of for a power trac. Steiner used to have loads of attachments but it looks like they got rid of some but Ventrac has quite a few.
02-24-2013, 08:07 AM #3Bronze Member
- Join Date
- Jul 2011
- Posts
- 73
- Tractor
- Steiner 430
I have a power rake. pallet mover and power blade that I would like to use with my 422.
02-24-2013, 11:12 AM #4
I looked up your items and on the power rake you will have to replace the gear box with a hydraulic motor and have it hooked up to the PTO and the leveler should just hook up the your auxiliary PTO. I think you could do the pallet mover but I feel you would be better served to just sell them at a good price and buy power trac forks with the money. You can convert the blade but it would take some cutting or some fabricating to make it doable. You will probably will have to cut off the steiner attachment forks and weld on a power trac quick attach plate in their place. That is what I did to my leaf blower. I have some pictures of it here on tractor by net along with 2 videos. If your handy at welding make your own quick attach plate. I did this for my samurai sickle bar I use on my Power trac. I am not a good welder but it holds together just fine.
02-25-2013, 10:15 AM #5Gold Member
- Join Date
- Nov 2006
- Posts
- 310
- Location
- Central NJ
- Tractor
- Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
Cool connection, You haven't posted pics of the sickle yet. I would love to see this. While you are at it any other attachments you have. You seem like the kind of guy who makes a lot of his own attachments.
Scott
02-28-2013, 06:52 PM #6
I know and I hope to get around to it sometime. I like to design, this is what I do for my job. I design knives and hand tools.
Similar Threads
Comparison of a PT to a Steiner or Ventrac
By Frank Sorbello in forum Power TracReplies: 2Last Post: 11-07-2012, 10:02 PM -
Used Steiner / Ventrac parts
By dwlandmann in forum Wanted AdsReplies: 2Last Post: 05-16-2012, 05:37 AM -
Steiner and Ventrac Attachments
By AVIVIII in forum AttachmentsReplies: 1Last Post: 03-31-2011, 02:49 PM -
Does my PT Mow as good as a Ventrac or Steiner?
By pequeajim in forum Power TracReplies: 25Last Post: 06-11-2006, 10:42 PM -
Ventrac/Steiner/425
By jakeman in forum All Other BrandsReplies: 5Last Post: 04-17-2002, 09:50 PM
