Results 1 to 5 of 5
  1. #1
    Join Date
    Dec 2001
    Posts
    92
    Hartland VT
    Power Trac PT-425 (2011)
    Default Broken hourmeter replaced for free (PT-425)
    Finally some good news in manufacturers standing behind their products. Out of the blue my hour meter lost "segments" and became useless: Broken hourmeter replaced for free (PT-425)-hourmeter3-jpg
    I was just about ready to email PowerTrac to order a new one, but first I wanted to see if I could buy a replacement from some Internet store (for probably less money).
    I admit I wasn't too happy when the old one broke at only 138 hours (insert commentary about how "they don't make things like they used to" here) and really didn't feel motivated to shell out money for a new one.
    I found the Hobbs 085094 44 at Granger ($89, yikes)
    Then thought maybe a mechanical one would be more reliable? Like REDINGTON 732-0004 ($44). There seems to be room enough for it (it is 2-1/2" long)
    I never sent the email to Powertrac so don't know how much they would charge.
    I tracked down SenDEC, which is now Global Digital Instruments. I used their comments page (https://www.gdimeters.com/contact/) to ask if there was any way to fix the meter (and to passive-aggressively suggest that their meter isn't reliable):
    "Message: Hi - I have a SenDEC model 807A-700-0111, v5.2 Elapsed Timer on my tractor. After just 138 hours on the meter it is now showing just parts of the numbers and is therefore unreadable (like my watch does when the battery runs very low). The case is epoxy sealed. Does this mean the meter is dead and needs replacement? I am about to order a replacement from the tractor manufacturer (hopefully they have one left over!) and was wondering if it is possible to pre-set the new meter to 138 hours? Thanks, Kent"
    To my surprise I received a personal response by email from the directory of sales and marketing within the hour:
    "I will send you a new one at no charge. It will be a new version whose improved internal electronics prevents from the segment loss issue. When you receive it, just power it with a 9 volt battery until it reaches 138 hours."
    I replied and thanked him profusely.
    Five days later I received the new meter, have it installed, and am cranking up the hours as we speak.
    I am using my little 12v trickle charger (with alligator clips) to provide the power (actually about 16 v). Though I believe that polarity isn't an issue, I did determine which post the hot lead from the ignition switch to the meter went to on the old meter and have used the same polarity while charging.
    So three cheers to Global Digital Instruments!
  2. #2
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    34,578
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Default Re: Broken hourmeter replaced for free (PT-425)
    Nice to hear about a company that cares. Good for them.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  3. #3
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    So,
    Is getting a new hour meter like getting a new tractor?
    It sounds like it is a known problem.
    It is probably cheaper to send a new hour meter only to those customers that complain than to try to get a replacement out to every tractor owner.
    Hopefully Powertrac either refers people to the manufacturer, or does a similar replace, no questions asked (other than S/N).
  4. #4
    Gold Member HarryN's Avatar
    Join Date
    Aug 2011
    Posts
    289
    Covington, Louisiana USA
    1999 Bobcat 763F John Deer 850 Grasshopper 723K H2
    Good that your effort paid off!
    Is there a way to "zero" a meter like that?? (like if you replaced the engine)
  5. #5
    Join Date
    Dec 2001
    Posts
    92
    Hartland VT
    Quote Originally Posted by HarryN View Post
    Yes, a small victory for the small guy.
    No reset on this meter (by the way the new hour meter part number is N430-0200-8111, no button). This is the base-level model, no frills. That is why I have to run a charger attached to the pins for 137 hours to set the meter at the previous meter's time. Personally I want it to be simple and not accidentally resettable. Time marches on.
    But the "NewGen Series" model at https://www.gdimeters.com/products/1...es-hour-meters can be, and also have many other functions controlled by a button (service warnings, timers, volts, rpm, time etc.). Some of these are pre-programmed by GDI for a particular equipment manufacturer. No heart rate monitor, however, which could be handier than a tiltmeter in some cases. I am confident that further searching could locate even fancier models (or I could ask my neighbor who could build one from scratch and also write the machine code to run it, but it just seems easier to live with a simple/cheap model that hopefully is reliable at doing just one important thing).
Similar Threads
  1. Oil & Fuel Changing hydraulic oil in 425 power-trac
    By Kaon99 in forum Power Trac
    Last Post: 08-01-2013, 08:18 AM
  2. RTV 900 Hourmeter Question
    By gelliot in forum Kubota Owning/Operating
    Last Post: 06-14-2007, 08:29 PM
  3. Help with Hourmeter
    By powershop in forum Owning/Operating
    Last Post: 05-01-2003, 01:44 AM
  4. BX hourmeter
    By fishman in forum Kubota Owning/Operating
    Last Post: 04-19-2001, 03:54 PM
  5. Kubota Hourmeter
    By JimBinMI in forum Kubota Owning/Operating
    Last Post: 05-14-2000, 11:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
