Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Mar 2004
    Posts
    813
    N Central PA
    PT 422
    Default A few finish mower questions
    I do not recall, but does anybody know the length of the belt on the 48" deck? Mine is looking a bit shabby and thinking having a replacement on hand would be a good idea. I know, I could just take it off and have my answer.
    Regarding the hard plastic rear wheels.....what has been done to replace those with something that doesn't dig up the soft ground as much? Maybe rubber wheel that takes air?
    Has anybody come up with a quicker way to adjust the rear wheel height? When I cut pasture I raise my deck to avoid hitting hidden rock or branches and while it's not a big time consuming task I wonder if somebody came up with a quicker way to do this?
    If diamonds are a woman's best friend then why does man's best friend like to drink from the toilet??
  2. #2
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,061
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    I'd look at the belt, 100"?!
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  3. #3
    Gold Member
    Join Date
    Sep 2006
    Posts
    392
    Owego, NY
    PT422 w/ EH72FI engine swap
    Default Re: A few finish mower questions
    For the hard plastic wheels, you could look into the rounded type. E.g.
    Or convert them to a caster wheel, which would be more costly and difficult, but could be done.
    You might be able to replace the bolts with a rod and cotter pin to speed up adjustment. Any play could be removed with washers.
  4. #4
    Join Date
    Mar 2004
    Posts
    813
    N Central PA
    PT 422
    I just got my 10% off coupon from TSC and I'll be looking for wheels like that when I make my next trip. The caster wheel option crossed my mind but will the deck move properly since the front wheels are also casters?
  5. #5
    Gold Member
    Join Date
    Sep 2006
    Posts
    392
    Owego, NY
    Good luck! Be sure to post pics and model numbers when done.
  6. #6
    Gold Member
    Join Date
    Sep 2006
    Posts
    392
    Owego, NY
    Oops... missed your question about the deck moving properly with casters.... I think so. You could make the argument it would put less "stress" on the quick connect plate and lift arms if done correctly.
  7. #7
    Elite Member KentT's Avatar
    Join Date
    Mar 2005
    Posts
    2,838
    Sevierville, TN
    1993 Power Trac 1430 w/Kubota diesel engine
    Make sure there's enough room without the casters coming in contact with the front tires.
    I replaced the plastic rear wheels on my 48" brushcutter with semi-pneumatic tires on metal hubs with grease zerks. Having upsized my PT's tires to 26x12x12, the rear wheels of the brushcutter will now occasionally contact the front tires when the brushcutter is lifted in the air. There's about 2" of clearance when the brushcutter is down on the ground... I don't consider the contact when lifted to be an issue, but I'm also not using swivel casters which take up more room.
    Power Trac PT-1430 w/Kubota diesel engine & numerous attachments
    Allis-Chalmers B-210 w/several attachments
    Yamaha Rhino 450 UTV w/numerous mods
    More pictures & info about my garden tractors
  8. #8
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,597
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    Fo my pt, I put chains on mt tires then got a big surprise when the ripped the rear mower tires off. Too little clearance between the whole setup.
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  9. #9
    Veteran Member SpringHollow's Avatar
    Join Date
    Dec 2006
    Posts
    2,326
    South of Rochester, NY
    Power Trac 1850, NH 2120
    Carl,
    I did the exact same thing. I am still deciding whether I will replace the wheels or not.
    Ken
    PT1850, mini hoe, grapple, stump grinder, brush hog
    http://www.usadiscountgenerators.com...T1850Home.html
  10. #10
    Join Date
    Mar 2004
    Posts
    813
    N Central PA
    PT 422
    Kevin, I like the look of that wheel...where did you find it? TSC had some nice rubber wheels that probably would be an upgrade but they were expensive at over $30 each.
Similar Threads
  1. YM186D MMM -vs- 3PT finish mower questions
    By curvecrazy in forum Yanmar
    Last Post: 07-19-2010, 12:48 PM
  2. Three Point Finish Mower Questions
    By Spaceman in forum Attachments
    Last Post: 09-24-2008, 09:20 AM
  3. More Rear Finish mower questions...
    By orlo in forum John Deere Owning/Operating
    Last Post: 06-12-2006, 11:43 AM
  4. finish mower questions
    By GaryS in forum Attachments
    Last Post: 05-04-2006, 11:29 AM
  5. Mowing 48" Finish Mower Questions
    By SnowRidge in forum Power Trac
    Last Post: 07-14-2003, 09:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
