Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,597
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    Default 90" Mower Deck modifications
    I thought I would write a long story about rebuilding the mower. I think, though, that most everyone here knows how to change out axle bearings, so I am going to forgo the experience. If you need pointers, happy to help out.
    I will post a few things that I change. #1 thing to know is that the bearings on my mower are open (not sealed). This means that in its current design, the upper bearing will not get any grease and is subjected to any weather or elements. When I put my mower back together I jammed the axle housing full of grease. We will see how this all works out.
    Second thing I did was my first oxy cut. I probably should have practiced first. And doing a punch cut is harder the first time around than a sever. Anyway, pix of the holes I cut. three holes to allow access to the top of the mower hub, and two small holes to allow water to drain out of the upper deck.
    Third, my neighbor looked at my spindle to repair and passed. He said that the shaft was cracking the metal of the rotor housing. Failure was immanent. I agreed so I took it to the local machine shop. $100 later and they welded in a support disk. Now when speaking with the machinist, he said the crack was at the weld (cold weld) and the metal under was good, but he said as this was the main drive no reason to not beef it up.
    Anyway, there it is. I have two tear apart notes. The pulley hubs are held together with a cone / compression type fitting. The cone has three bolts in it. You remove those three bolts and move them one notch over and screw them back in and that pushes the hubs apart. Also there is a lock key on all the hubs
    Second, on my tractor getting the center pulley off with the housing that supports the hydraulic motor prevented my gear puller from working. Thankfully my neighbor had a flat sided gear puller (think of it as as the pulling legs are 3/16 hardened L shaped grabbers).
    Attached Thumbnails Attached Thumbnails 90" Mower Deck modifications-img_20130815_163310_960-jpg   90" Mower Deck modifications-img_20130815_163319_373-jpg   90" Mower Deck modifications-img_20130815_163328_092-jpg   90" Mower Deck modifications-img_20130815_163241_504-jpg
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  2. #2
    Elite Member
    Join Date
    Jun 2006
    Posts
    3,005
    West Cascades, Washington State USA
    PT 422
    Default Re: 90" Mower Deck modifications
    Nice write up and thanks for the picts.
    Though i don't know whats wrong with your oxy cut, looks pretty good to me.
  3. #3
    Join Date
    Jul 2006
    Posts
    5,597
    It looks like I got severe Parkinson's, my circles are squares, and there is enough slag on the bottom to build another mower. I guess plasma would cut better?
  4. #4
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    34,819
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    If those were your first cuts every you done good, bud!
    Cutting a circle freehand with a torch is not an easy task. I'll ask you this.... can you draw a circle freehand any better? I can't.
    A couple tips....
    get a soap pencil and use a template to draw the circle first.
    pre-heat the cut line for a few minutes by going over it again and again slowly with the torch before you apply the oxy.
    ORrrrr..... get a bi-metal hole saw for your 1/2" drill. They work great, but don't have the smoke, fire and molten metal that we all crave...
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  5. #5
    Join Date
    Mar 2007
    Posts
    1,550
    Bay Area, CA
    Power Trac PT1445
    I agree with MR, they look good from here.
    I can't freehand anything. For me, it is a soap pencil, and try to follow a template.
    I do have a drawer of nice hole cutters. As MR said, they lack the speed, smoke, and sounds of plasma or oxytorches, and you could call bimetallic hole saw boring, but there are times in life for being boring.
    All the best,
    Peter
  6. #6
    Platinum Member tmarks11's Avatar
    Join Date
    May 2005
    Posts
    922
    Seattle, WA
    Power Trac 422 (2005)
    The trick with the hole saw on 1/4" metal is cut it slow. It is too easy to wipe the teeth by letting it spin too fast and heating it up too much.
    Tim
    2005 PT-422
    4n1, LMB, minihoe, 48" mower, brush hog, Land Pride aerator, Herd spreader, auger, towing, forks, box blade, plow, box blade, tiller, trencher
    PT422 (6/23/05) photo page
  7. #7
    Elite Member BobRip's Avatar
    Join Date
    Sep 2004
    Posts
    4,490
    Powhatan Va.
    2000 Power Trac 422
    Quote Originally Posted by tmarks11 View Post
    A lube helps too.
    Bob Rip
    Tell me and I will hear.
    Show me and I will see.
    Let me do and I will learn.
    Let me fail and I will understand.
  8. #8
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Carl,
    Perhaps your deck has a cover on it, but
    Why not use sealed bearings especially as the top bearing. You could have removed the bottom seal on the top bearing, so you could pump grease in there. Does your spindle assembly have a grease zerk?
    Any water that gets to your bearing will also run down into the hub. You might need some holes there also.
    A trick in cutting holes is to drill a small hole in the center of the circle, and bend a metal wire into an L shape and the radius of the circle and bend a circle so the torch head fits in and allow cutting a good circle. I do this with my plasma cutter also.
    A magnet and wire will work also.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  9. #9
    Elite Member
    Join Date
    Jun 2006
    Posts
    3,005
    PT 422
    Quote Originally Posted by J_J View Post
    That's a neat trick.
  10. #10
    Join Date
    Aug 2001
    Posts
    34,819
    Quote Originally Posted by cqaigy2 View Post
    It called "ask an old dude with a ton of life exerience that's willing to teach".
    I've met a lot of guys with tons of experience that aren't willing to help but quick to criticize. J_J's not one of those. Thanks, J_J!
    MossRoad
    Of It In Action!!!
Similar Threads
  1. Replies: 5
    Last Post: 09-12-2014, 06:31 PM
  2. 1960s sears ss12 mower deck master pully "replacement"
    By Tristen124 in forum Parts/Repairs
    Last Post: 09-11-2012, 08:27 AM
  3. B2410 - How do I "pin" the mower deck
    By jfdlaw in forum Kubota Owning/Operating
    Last Post: 05-14-2012, 07:30 AM
  4. Mowing Mower deck for 2518, any advantage of 48" over 44"
    By mc25a in forum Cub Cadet Tractors
    Last Post: 07-30-2009, 05:54 PM
  5. Mower Deck: "Float" or "Hang"
    By ancientlake in forum General Lawn & Garden
    Last Post: 04-25-2008, 11:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
