Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    3
    harvey lake PA
    power trac 1850
    Default power trac 1850 control issues
    i purchased a power trac 1850 on the cheap . I like problems .the info i received with it is useless , and with the fresh
    coat of red . cant read anything . Can anyone post pictures of controls ,or point me in right direction ? Manuals ? for sale or on line ?
    Can only get 2 wheels turning to start with . Thanks for any help i receive . Will not be my last post . Will try to post pictures .
    Thanks Kevin In PA
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: power trac 1850 control issues
    Hi Kevin,
    Welcome to the Power-Trac forum.
    There are several people here that own 1850's.
    Don't know about the manuals, as they are very poor.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    32,330
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Welcome to TBN. Have you spoken to Terry at the factory yet?
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  4. #4
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,612
    West Cascades, Washington State USA
    PT 422
    Welcome aboard Kevin.
  5. #5
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,344
    Los Angeles / SW Washington
    PowerTrac 1850
    Kevin. I am happy to help,so will be ken the other 1850 owner. Big thing we need is some pictures of your machine. While pt doesn't change much we are all always surprised by changes.
    I think my big questions are.....n what're kind of engine do you have? When you operate the treadle, the foot controls, are there hydraulic hoses connected to them or cables?
    All the pt's have the same basic design, and the guys in this group are amazingly helpful.
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  6. #6
    Join Date
    Jul 2006
    Posts
    5,344
    PowerTrac 1850
    As JJ said, the manuals are terrible. They give you NO useful information, not even how to start or stop.
  7. #7
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Perhaps you can tell us more about your machine , such as how old, which engine, pump manufacturer, size tires, dual tires, how many attachments, etc,
    I would highly recommend a 3000 psi gage to help you monitor and trouble shoot the hyd system.
    If you know how to use the search engine, you might just read everything that has been posted about the 1850 till now, plus ask all the questions you want.
    I have a PT-1445, but might be able to help a little.
    J.J.
    Git er done.
  8. #8
    Super Star Member
    Join Date
    Mar 2008
    Posts
    14,736
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Quote Originally Posted by J_J View Post
    If you go to Search Results - TractorByNet.com that should list all threads with the number 1850 and either PT or Power Trac.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  9. #9
    New Member
    Join Date
    Aug 2013
    Posts
    3
    harvey lake PA
    power trac 1850
    power trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpgpower trac 1850 control issues-image-jpg
    Spoke to terry machine us a 94. Will replace
    Gage . Will Chechnya if front pedals are
    Connected to hose or cable . Have with
    It plow and tractor bucket. Looking to get
    Brush hog when working.
    Thanks for all the replies keep them coming
    Kevin. Hope pictures come out
  10. #10
    Join Date
    Jul 2006
    Posts
    5,344
    PowerTrac 1850
    WOW. Completely different than Either Ken or My 1850, but I think JJ's 1430 has some similarity.
    Evertthing so far makes sense, except for the lever on the center column. JJ, any ideas?
    So you have got it running? engine turns over? And then you take the brake off (this would be the handle on the left side in front of your knee, it is the brake as well as the brake release). so that you know, there is no braking on a PT, for the most part they hold position on hills pretty well when running, but of course you need them with the engine off.
    I am pretty sure you have a cable drive for the wheels, which means the foot pedals use a cable run to the hydraulics on the engine that either push fluid forward or reverse. Newer models use hydrualic lines to provide that control.
    Does your PT steer? Does the arms move up and down?
    My PT has 3 different hydraulic pumps. One drives the wheels only. One drives the steering, lift tilt dump, tilt seat, and float (maybe brakes, never checked that). The last pump is purely the PTO pump. Hopefully this info will help you start to suss out the drive train issue.
Similar Threads
  1. Hydraulic problems Power Trac 1850
    By PowerT1850 in forum Hydraulics
    Last Post: 01-18-2013, 03:18 PM
  2. dodge grand carivan ABS/trac control?
    By Soundguy in forum Parts/Repairs
    Last Post: 07-16-2009, 08:57 PM
  3. Bobcat Toolcat 5600 or Power Trac 1850 for 168 ac?
    By BrianSouthernMD in forum Buying/Pricing/Comparisons
    Last Post: 09-18-2005, 07:47 PM
  4. Power Trac Draft Control
    By duane in forum Power Trac
    Last Post: 08-28-2003, 02:00 PM
  5. Trac-hoe control ?
    By Richard in forum Related Topics
    Last Post: 10-09-2001, 02:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
