MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,117
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I've been debating whether or not to mount lights under the canopy. As most of us know, the lights mounted on the PT425 are inadequate for lighting up what is directly in front of you. They work great towards the sides, but cast a shadow directly on the quick attach area and an implement like the snow plow or bucket will cast a shadow right in the work area. So several of us have mounted extra lights under the canopy. I am finally giving in and doing the same. However, I didn't want to drill through the canopy and have a bolt head or nut sticking out of the top. So, today, I mounted a 1.5" X 1.5" inch by 1/8" thick square steel tube under the canopy to attach lights and a rear view mirror.
The first picture is of the canopy being removed. I removed the canopy because I wanted to weld the square tube to the underside of the canopy and, being the great welder that I am, knew better than to try welding upside down /forums/images/graemlins/tongue.gif. To remove the canopy, there are just 2 bolts per side with nylon lock nuts. I loosened them all to the point just past the nylon. I then removed the rear bolt on one side. Then, I held the canopy while my wife removed the other rear bolt. The canopy was then tilted forward on the two front bolts just like a hinge. I set a 2X4 so that I wouldn't pinch my toes or fingers off if I dropped the canopy. I found that if you don't put a 2x4 down there, the canopy won't hit the ground anyway, because the ROPS hits the front tires, but I imagine that it could bounce and still hurt your toesies, so better safe tahn sorry. Pretty easy. I estimate the weight of the canopy/ROPS assembly to be under a hundred pounds. It handles easily. It went back on the same way.
