425 w.1430 wheelmotor boxes and 28.3ci wheel motors
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Finally had an opportunity to snap a couple pics of my 425 in use, after upgrading the wheel motors. Here's a couple pics of its stance with 26x12x12 Deestone lug tires and the larger Surplus Center wheelmotors that come with brake drums/hubs:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #2
Nice! :thumbsup:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #3
Good gravy that's a wide standing mountain beast!!! :laughing:
Any problems with the front and back tires hitting each other at full turns?
No, they don't hit. But, they're about 12" apart when fully articulated...
And it works well on these slopes:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #5
Nice.
That would solve two problems that I have notice: insufficient clearance between wheels and frame for tire chains, and weeds getting choked up between wheel and body when brush hogging. At least a couple of inches more clearance would be nice.
Did you have to replace the hydraulic hoses?
No, just pulled the existing hoses out a bit. Did require buying adapters for the fittings, though...
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #7
Did you hook up the breaks? My tractor's 11years old and I think those pin breaks have been frozen for 10.
No pin brakes. I'm trying to find used backing plates for cable-operated drum brakes. I understand EzGo may have used them on golf carts in the 1980s or so that are the same size -- 5.25 in (625mm).
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #9
Nice. Looks like a real beast.
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #10
12" between tires at full turn is mor than I have now. Nice!
What's the width outside to outside now?
Decorative Bear and Stump Statue (A55758)
Decorative Bear...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2013 International TerraStar Enclosed Service Truck with Liftgate (A55788)
2013 International...
Duetz Power Unit (A50120)
Duetz Power Unit...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55301)
2023 NEW HOLLAND...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
