1850 Hydraulic pressure pulsates - any theories for cause?
   / 1850 Hydraulic pressure pulsates - any theories for cause? #1
MikeOConnor
Western Wisconsin
Two Power-Trac 1850s (preferred for mowing and grapple-bucket clearing type work on really steep hills). Kubota M680 for snowblowing, grading, bucket.
Hi all,
I've just laid down a huge time-consuming piece of volunteer work which means I have a lot more time to get in trouble with my 1850. :)
So today I decided to do the routine maintenance and replace the hydraulic filter. When I fired up (after bleeding), the hydraulic pressure started pulsing. Normal is around 1500 PSI, the pulse-range is between 1300 and 1700, about once a second. Here's a link to a 7-second Youtube video that shows what's going on.
https://www.youtube.com/watch?v=m2-dF9ZIkfg
So I bled it again, just for good measure. Same deal.
This happened once before and the theory then was a blown seal in the pressure-relief valve. That valve is dry as a bone this time, and the only thing that's changed is a new filter.
Is this something that somebody's seen before? Just curious. I'm planning to call Terry on Monday, but just curious to see what TBN folks have to offer.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #2
Possibly air is be pulled in from somewhere? When you bleed, im assuming no air whatsoever? I had an issue with the filter not being set down well and it would pull air when i was bleeding the system. I'd lubed the seal on the filter good but just needed about 1/4 turn more.
Thanks for the tip. I'll have a go at reseating that filter tomorrow and see what happens. Bleeding didn't have any air in it, but there's a lot more oomph when the PT is actually running rather than just cranking over. I would love that as the fix.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #4
Weird, I would agree with checking the filter but you would think you would see foam if this was the case. It might also be a bad filter.
Dang, that simple fix didn't pan out. I reseated the filter and bled it again. Still pulses.
I kinda like the "bad filter" idea. Unfortunately this is the last filter in the box so I can't try that idea out today.
Any other theories people want to lay on?
I'm wondering if something else is failing -- and if so, how do people go about isolating various parts of the hydraulic system to narrow down the cause? Is there a tried and true way of capping off various circuits one at a time?
   / 1850 Hydraulic pressure pulsates - any theories for cause? #6
Well, that is very odd. It's almost like a relief valve is cutting on and off. What about disconnecting the PTO switch or value. Not sure about the engine bay configuration on an 1850 but maybe you're getting a short or something related to the PTO...since you were in the engine bay to change the filter.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #7
Out of curiosity, which hydraulic circuit is showing this pulsing?
   / 1850 Hydraulic pressure pulsates - any theories for cause? #8
Dear Mike,
Since all you did was change a filter, I would go with the air leak or bad filter. I have once had a filter that required 3-4X the normal force to seat properly. An examination of the o ring and can didn't show anything obvious to the naked eye, but the pump cared. I noticed mainly by oil misting out of the cartridge.
Are you seeing mini bubbles coming back into the hydraulic tank? At some point, you would be getting air back through the case drains.
If not, it may just be that something else failed at the same time. Is it possible that you have the draft control on, or that the automatic brake circuit is in trouble (that should kick in about 500psi, so it seems like a stretch.)?
Good luck!
All the best,
Peter
Hi folks. Thanks for the thoughts...
- the relief valve has been a problem child on this machine for several years. I think I'm on my 4th or 5th rebuild (I think mostly because it dies during really cold weather work - like 0 to 10 degrees). But in the past it's failed by blowing seals and then leaking. This time around it's behaving pretty well -- nice n'dry.
- the pulsing starts as soon as I start the PT -- I can hear that slight variation of engine RPM. But I don't know how to determine which circuit is actually where it's pulsing. Is there a good way to figure that out? That would help immensely.
- I really cranked on the filter this time around, thinking that might seat it better. I don't see any leakage from around the filter, it stays dry too. So I'm thinking that something else has coincidentally failed too. I've got the mower hooked up, so the draft control was on. I disconnected the mower and turned off the draft control, but that didn't do it.
Terry has something to try -- this happened to me once before and he told me something to do, but I forgot to write it down so I'll ask him again tomorrow morning. Last time around that didn't work either and we replaced the pressure-relief valve.
I think something else is failing and stressing the whole system. The hydraulic pressure often "hangs" up around 2500 PSI. A quick flip of the Brake Tender clears it up. That's not the same problem, but whatever is causing that may be why the rest of the system is over-stressed and failing in these flaky ways.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #10
Dear Mike,
Thanks for the extra details. It sounds like either a pressure relief or the automatic brakes are acting up. I'd be interested to hear what Terry has to say.
All the best,
Peter
   / 1850 Hydraulic pressure pulsates - any theories for cause? #11
????????????Oillevel checked and ok ?????????????
Hi all,
Talked to Terry after the "Monday rush" died down (first time I called right at 9:15am and their poor phone system was melting under the number of calls).
Terry said that the first thing he'd try if the machine was in the shop would be to replace the brake-tender and I liked that theory for several reasons. I went back out yesterday and gave the PT a hard looking over. One thing I hadn't noticed before was that somewhere along the way I smacked something into the brake-tender hoses and one of the connection fittings is really badly bent -- and the hose is kinda whacked as a result. So a rebuilt brake tender is on the way. If I'm lucky I'll have it by Sunday and can take a run at putting it in.
BTW, oil level is fine.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #13
Thanks for the update. Man...when Terry leaves, and with no dealer network, I don't know what we'll do. Keep us posted.
Count me in on the Terry Fan Club. We should all head out there for his retirement party, whenever it is.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #16
That would be a blast. Count me in on the fan club as well.
All the best,
Peter
Hm. Here's a picture and a related question. As I look at the brake tender that is gonna get replaced, there are two hoses (the ones with "101" and "73" on them) that got clobbered. The two elbow connectors are going to have to be replaced for sure, no big deal.
It's hard to see, but the ends of the hoses also look like they need replacing. The connector-nuts are a little stripped, and the barrels of both have been flattened a little bit. The question, from a hydraulics newbie, is: do I have to replace the whole hose or can I just replace that connector at the end with some kind of crimp on thingy?
By the way, I know that somebody had a go at doing a diagram of the hydraulic system, but the new search tools on the forum haven't been a big help in finding it. Can somebody point me at it? I'm a little edgy about what may be coming if I have to replace those hoses and would like to get a sense of where the other ends of those two lines wind up.
Click on the picture below for a bigger version that's easier to make out.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #18
Are you sure the hoses need replacing? They don't look that bad in the picture. I'd take them lose and inspect. If you replace them, you'll have to put a cap on each end of the new hose, to avoid contamination, as you snake them around. Also, you probably can't crimp a new fitting on. I'd take the full hose to NAPA or a hydraulic place and have them make an exact copy.
Can't help you with the hydraulics diagram. I seriously doubt anyone has created a diagram. Do you have a manual? The manual should show the end location.
I'll kinda hang loose on the hoses and see what I discover when I take 'em off. Fingers crossed, they'll be OK.
I'd be curious if anybody with an 1845 or 1850 manual has a hydraulic diagram in theirs. Mine is a series of parts lists for the various modules and that's it. There isn't any mention of hoses, nor is there a diagram. But maybe newer versions of the manual have something like that? I'd cheerfully pay for another copy if it's been updated that way.
   / 1850 Hydraulic pressure pulsates - any theories for cause? #20
Mike, i have a bunch of stuff... Lemme see if I can upload it from Buenos Aires. If not, hit me with your private email...
  • 1850 Hose List Pg 1.pdf
  • 1850 Hose List Pg 2.pdf
  • 95418d1202568603-pump-pix-hose-list-pt-hydro-1.pdf
  • 95419d1202568618-pump-pix-hose-list-pt-hydro-2.pdf
  • 95420d1202568632-pump-pix-hose-list-pt-hydro-3.pdf
  • 95421d1202568644-pump-pix-hose-list-pt-hydro-4.pdf
  • 95422d1202568661-pump-pix-hose-list-pt-hydro-5.pdf
  • 95423d1202568673-pump-pix-hose-list-pt-hydro-6.pdf
  • 95424d1202568690-pump-pix-hose-list-pt-hydro-7.pdf
  • 95425d1202568705-pump-pix-hose-list-pt-hydro-8.pdf
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
case 370 glass door never installed (A56438)
case 370 glass...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
