Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2008
    Posts
    130
    Default Log splitter
    Finally had time to build this baby log splitter. It is about 8 tons and does what I need it to. Built it for under $250 with parts from Surplus Center.
    Attached Thumbnails Attached Thumbnails Log splitter-image-696942750-jpg   Log splitter-image-1711949961-jpg   Log splitter-image-2195569073-jpg   Log splitter-image-1577318807-jpg   Log splitter-image-2828319126-jpg
  2. #2
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    34,793
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Default Re: Log splitter
    Tested it out yet?
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  3. #3
    Join Date
    Feb 2008
    Posts
    130
    Default
    Yes I split some 8" oak with no issue.
  4. #4
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,695
    JD, Massey, Kubota, Case
    Default
    Nice.
  5. #5
    Join Date
    Jun 2006
    Posts
    71
    Dayton, Pa
    Power Trac 425
    Very nice. What size cylinder did you use
  6. #6
    Join Date
    Feb 2008
    Posts
    130
    Default
    I think it is 3"
  7. #7
    Join Date
    Mar 2004
    Posts
    813
    N Central PA
    PT 422
    Nice job! Next you need a cradle on that beam, sure has saved my back over the years.
    If diamonds are a woman's best friend then why does man's best friend like to drink from the toilet??
  8. #8
    Join Date
    Feb 2008
    Posts
    130
    Default
    Yes a cradle is in my plans. Have a few other things at the top of my list now so it my be awhile.
  9. #9
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    3 in cyl, 1.5 shaft
    At 2500 psi you would have 8 ton +
    At 3000 psi you would have 10 ton +
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
Similar Threads
  1. Mini Splitter Air/Hydraulic Log Splitter
    By BobRip in forum Build-It Yourself
    Last Post: 02-24-2015, 08:00 PM
  2. Log splitter log lift ? Simplest valve ?
    By CalG in forum Hydraulics
    Last Post: 03-05-2014, 08:54 AM
  3. Log splitter valve for a 3 point splitter
    By Rio_Grande in forum Build-It Yourself
    Last Post: 10-28-2011, 01:39 PM
  4. Splitter wedge mount location on log splitter-
    By beergut in forum Build-It Yourself
    Last Post: 07-16-2009, 06:25 PM
  5. Log Splitter makeover, with log lifter
    By Bigbear in forum Build-It Yourself
    Last Post: 09-10-2005, 09:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
