Hello to everyone on the forum, I must admit I have been lurking on and off for the better part of a few years ... Probably should have started posting quite some time ago.
Anyhow, the vast majority of my time has been spent on a pt180 (I don't know the vintage but it has a Briggs vanguard in it ... Potentially a second engine) that was more or less kept in immaculate condition by the previous owner. The hour meter reads around 1200 hours for what that's worth. The only modifications I have made to it have been replacing turf tires with industrial loader tires and dishing out the rims for better stability on hills. The tractor is mostly used for towing a trailer on hilly terrain and some very minimal brush cutting (more along the lines of mowing down a few areas of a five acre plot twice a year)
Granted its a tiny machine, but for what I need it to do I wouldn't dream of replacing it. It routinely tows loads up 25 to 30 degree slopes, slowly ... About 1/4 treadle. I am very used to balancing forward or reverse movement with PTO loads to avoid bogging or stalls on this little workhorse . . .
Now for the part that I am baffled over ...
My father purchased a used pt425 about 2 years ago and last month he bought a used pt1430 (lucky me for all the jobs a pt180 isn't quite cut out for!). Both of these machines don't climb nearly as we'll as the pt180 ... I wouldn't assume they would be directly on par based on their weight differences but the pt1430 is particularly alarming.
The pt1430 has about 3100 hours on it and is in good condition, no frame cracks or engine problems etc... However it will not drive up a 13 degree incline without stopping part way up the hill. The engine does not bog and I do not hear any whine from the wheel motors. The amount of treadle depressed seems to have no effect on forward movement up the incline either . . . Actually, without full treadle depression the machine will roll backwards after forward movement stops. Additionally, on one part of the hill, one of the front wheels will loose traction and spin, the spinning can be stopped by merely pushing on the tire with my foot from the operator seat (i know not smart, but what can I say, I tried).
Is this typical of a 1430 or is the tram pump,or wheel motors worn? My knowledge of hydraulics is limited at best and I haven't been able to find a thread that specifically deals with an issue such as this (if you know of one please point me in the right direction)
I did speak to Terry at PT briefly and he said the tram pump was the first place to start ... IE pay 1600 bucks for a rebuild and see if the problem is fixed ... My issue is that I don't know how well a 1430 can typically climb so I'm not sure if I even have an issue ... I just know that my little pt180 seems to feel WAY stronger while driving on slopes than the 1430 (which doesn't seem logically correct).
I also took a video of the machine on the test slope ... If that would be helpful to see ill figure out how to post it, just let me know.
Any input would be greatly appreciated, and no worries, if I am missing something obvious, I'm not easily offended!
