Barryh
- Joined
- Jul 5, 2005
- Messages
- 1,481
- Tractor
- Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Well finally got home last night had a chance to look over my tractor briefly ..
For the most part hoses and everything look nice and dry.. Surprisingly not much dirt in the tub.. Starting to think this guy was telling the truth and the tractor only has 631 hours on it .. Indicators I notice the bucket edge hardly any scratches on it not bent, tires are supposedly original ... Hardly worn.. Hard to believe for a 96 or 97 ...
Did notice the coalescer filter base was made of plastic and had a crack in it, when you put your finger on the bottom valve it was wet from gas.. So I need to find and order a new one. While I'm at it going to order all new gas hose and filters for the Kohler engine..
My question is has anyone by passed the coalescer temporarily or permanently. Until I can buy a new one, I would like to run the tractor around and check other areas. Has a regular filter on it . coalescer as far as I know are only there to keep out water.
Does anyone have a good source for a new one. I've found a few online for Marine engines they filter up to 10 microns for a 4 cycle engine and it looks like they will work just fine.
