I think the problem is flooding.
I have the fuel injected 28 hp Subaru Robin in my PT425 and have been having the problem lately of what I think is a weakening fuel pressure regulator that is built into the FI throttle body. As far as I can tell there are no schematics, rebuild instructions, or replaceable parts for the throttle body. On hot restarts half the time the engine floods and won't restart. So I have learned to "simply" shut off the fuel petcock I had installed under the gas tank, crank a few times, and it starts right up. Open the petcock after the engine catches, and I am good to go.
I used to think it wise to turn the key and pause for a second to let the fuel pump get up to pressure at the throttle body on cold starts, and that worked for many months, but now all that does is flood the engine. There is just too much gas in the cylinders at startup, both cold and hot.
So rather than turning the petcock every time the engine floods I am contemplating mounting a switch on the dash to control the power to the fuel pump, turning it off until flooding is cleared.
The non-FI Robin has a the vacuum powered fuel pump. I am thinking a normally open solenoid valve inserted into the "pulse pipe" between the fuel pump and then engine would do it. Search EBay for "1/4 inch NORMALLY OPEN 12V DC Solenoid Valve" for samples. Also install a 12v switch to control the solenoid.
