Barryh
- Joined
- Jul 5, 2005
- Messages
- 1,481
- Tractor
- Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
I have been slowly doing maintenance to my PT getting it ready for spring. I Just cleaned out the gas tank and installed new filters and gas hose. I am cleaning the carb and have a new fuel pump on the way. Also just bought a new marine water separator with filter the same setup that came with the Kohler. Of course could not get the original they stopped making them but the new one works perfect.
I have been watching for the hydraulic cooler fan to come on while the tractor sets idle. So far have not seen it kick in. How long before it is suppose to come on after the engine is running idle?
I hooked the old fan up directly to make sure it still works. It does so if it's not coming on guessing this is the thermostat and I will need to order a new one..
How many of you have just wired the fan up directly so it is always on.. I would think the fan would burn out quicker this way but would keep the hydraulics and engine cooler thinking I like that idea better.
Any one done this and how did work out. Not sure where I can get another fan, my guess I will have to modify with an upgrade this one when it burns out..
