JerryK
Elite Member
- Joined
- Feb 21, 2004
- Messages
- 3,266
- Location
- Vanderbilt, Michigan, USeh?
- Tractor
- Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
I just have a 54" blade on the front of the JD 420 that I turned into kind of a snow push box. If I buy one next summer, it will mostly be used in the Spring/Summer/Fall, but needs to do light snow duty especially in early winter when I am building my base. I could get buy with a lighter duty cable or strap type chain, especially if the unit had all wheel drive. Pushing is not sometimes the worse part, it's backing out of the pile a little up hill on ice or wet slush that sometimes gets my JD stuck. I would be going with the turf tire like on the JD, that seems to work best with just about any type of chain unless you wanted to go studs. Thanks..!!! [ here is20hp a couple pictures of what I want the PT-425 to replace.. 4 AllisC 100 pound suitcase weights on back, chains on rear, and cheepo push box... 20hp Onan hydrostatic 2 wheel drive with two speed locking rear axle ]
