woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,118
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
So as no one is posting but me, figured I would share this repair.
I have been battling rust in my tank for quite some time, and figured now would be the best time to get it tackled. The plan is to cut the top of the tank off and make an access point, sand down the inside and use POR-15 to seal the tank back up.
The results - This will be over a number of days so enjoy...
The tank came out super easy. Remove the battery, disconnect the filters and valve control that hang off the tank, and remove hoses, then take the bolts off and bobs your uncle, you have a tank.
So took the tank directly over to the hose to wash out the remaining diesel. As you can see, it was not pretty. And this picture was after a 20 seconds of me standing there stunned.
Next up I found that the area behind the battery was in very very bad shape. The metal is actually impacted (it is 1/8" thick btw). Not just surface rust bot some serious etching. Guess I am getting another can of POR.
So took the tank back to the welding table and filled it with water, grabbed my plasma cutter and cut out my work piece. Then I drained the water, and found out that the space between the fill line and the top of the tank was very rusted. More so than the body of the tank, although the bottom of course had a bunch of rust.
Here is the top, you can see the rust. and you can also see the hole I cut...
Finally, just adding a picture of what the tub looks like without the tank.
Tomorrow the inlaws are swinging by for the day so Monday I will get back into it.... pan is
Make the top plate
Power Wash the inside of the tank and sand and grind
Prep and POR the inside and outside
New paint
Put the bad boy back together
Oh, as a fun side project, I am going to drive the tractor, without the gas tank (going to put a fuel hose in a jug of gas and lay the batter on the pumps) and drive it over to my pressure washer. Probably going to find some petrified stuff in there as the oil and gunk is so thick.
Make the top plate
New paint
