Where do i put this or keep that?
   / Where do i put this or keep that? #31
I thought I would bring this to the top since we are discussing modifications.
Bob Rip
   / Where do i put this or keep that? #32
I thought I would bring this to the top since there is some recent interest.
Bob Rip
   / Where do i put this or keep that? #33
I added an ammo box on the large post between the front lift arms nearest the operator. I drilled holes in the bottom of the box and ran tie wraps through the holes and around the post. You can adjust the position forward and backwards by rotating the box on the post. You have to do this because in the backwards position it hits the console when the arm is up and in the forward position it blocks your view of the attachment. It may also stop wood chips when stump grinding. I have not tried this yet. This is not the best modification I have made and you have to consider it for your needs. Another disadvantage is it reduces your lift capacity, not by much of course.
It is a good place to put your gloves since you can reach it while sitting. Also good for silicon lube.
