Root Rake/ Grapple combo
   / Root Rake/ Grapple combo #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
This is similar to what I started with. A hitch assembly, and 9 box blade ripper shanks.
Fiinished product.
This all took a bit of welding, and fitting the hydraulics cyl to work properly . Cost , hitch $40.00, Shanks $15.00 each, 4 inch 1/2 inch steel, free. Used a Lincoln 175 mig. About 20 hours rounding up the parts and welding.
Hardest part was drilling out the end hole in 4 of the shanks for 3/4 grade 8 bolts. That is some some hard steel. Wore out 4, 3/4 bits. I had to torch out the holes, and ream with 3/4 carbide reamer.
Every thing turned out according to plan.
It will not grab a large bite, but the 3/4 steel shanks will handle all my tough stuff.
Grapple closed.
   / Root Rake/ Grapple combo #5
J.J.
Very impressive. Your work is on the scale of a professional manafactory plant.
Thanks for sharing your talents.
PJ
   / Root Rake/ Grapple combo #6
Good job, JJ!! I need some kind of grapple arrangement for moving cut brush to the bonfire, that looks like it might just do the trick. Got a MIG welder for Christmas but haven't had anything to weld yet... this'd be a good project. AND I already have the hitch, so I'm $40 ahead already.
Thanks for the idea and photos.
Phil
   / Root Rake/ Grapple combo #7
I'm curious J.J., why did you use a hitch instead of some square tube? Was it because of availability?
   / Root Rake/ Grapple combo #8
Real nice looking grapple JJ .... looks like it will work well for a lot of stuff and the price was right.
I had several of these laying around, and the price of steel seems to go up every day. Steel tubing would have worked.
It just worked out well for a small sturdy grapple/root rake.
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2016 Case 580N EP Backhoe, S/N JJGN58EPLGC729072, Diesel Engine, 4 x 4, 80" Front GP Bucket, 22" (A59076)
2016 Case 580N EP...
Deere 350G LC (A53317)
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
Terms & Conditions of (Buying through EquipmentDealz Auction) (A59213)
Terms & Conditions...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
