Carpenter
A friend of mine has a brush mower that I borrow once in awhile. I used it the other day and had the bolt that holds one of the blades break. I was lucky enough to find the spacer and washer in the grass and after extracting the broken bolt and replacing it with a new one the mower was back in business. The next day my friend went out to mow and the other bolt broke. I'm posting this as a heads-up to have some spare bolts, washers, spacers and a 5/8" easy-out on hand. This mower has been used hard for about 3 years and has hit many rocks so I don't think this is a premature bolt failure. The fatigue rate was amazingly close on the two bolts as the second one broke about 15 minutes (of use) after the first.
