Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 42
  1. #1
    New Member
    Join Date
    Jun 2005
    Posts
    16
    Leesburg, VA
    None right now...
    Default 422 versus 425
    Hi All,
    I've been looking at Compact Tractors for the last couple of months and came across Power-Trac through this forum. Everyone here sounds very happy with their machines and seeing what they can do is making me rethink my original plan of a regular CUT.
    What are the primary differences between the 422 and 425? This is what I've been able to gather so far:
    22HP versus 25HP
    52" versus 60" lift
    No ROPS versus ROPS (is a ROPS available for the 422?)
    Other than that, they look very similar, including the 800lb lift capacity. Almost all of the attachments are the same between the two models.
    This would be for homeowner use only so I wouldn't need a commercial warranty.
    I'm sure Power-Trac doesn't just increase the price by $2,500 to get a couple of HP and a commercial warranty. What am I missing? Is there anyone on the board that regretted getting the 422 and thought they should have gone with the 425?
    I'll post another message with some thoughts on projects I'd be doing with the PT, mostly loader/grading/digging work. I have a ZTR mower that I use for the grass I won't be replacing.
    Thanks!
    - Phil
  2. #2
    Join Date
    Jan 2004
    Posts
    703
    east TN
    Power-trac 422 2003 model and 428 January 2015 model
    Default Re: 422 versus 425
    The last I looked at the factory the new 425 is now 8" longer than the new 422. The new 422 has only one stearing cylinder located on the left hand side. Where as the 425 has 2 one on eather side. I assume that the 425 Rops will still fit the 422. It cost $500 at the factory. Some one had a used ROP on PT's web site.
  3. #3
    Join Date
    Jan 2004
    Posts
    703
    east TN
    I forgot to mention the 30% stronger wheel motors that the new 425 has. NICE!!!!
  4. #4
    Join Date
    Apr 2005
    Posts
    154
    Atascadero, California
    I too have been going through the same evaluation. Besides the items that you list, from what I can see there are the following differences:
    1. Weight 1260 for 422 and 1387 for 425
    2. Length 83 vs 90
    3. Wheelbase 48 vs 56
    4. PTO same 8GPM at 2500 PSI
    5. ROPS optional on 422
    6. Speed 8MPH vs 10 MPH
    7. One inconsistency between the web site and PT brochure is the Hydraulic oil tank stated at 5 gallons in the brochure and 10 gallons on the web for the 422 while the 425 is at 10 gallons on the web and the brochure.
    I don't know if the difference is in the wheel motors or some other aspect of the machine but I as you think there has to be something that is attributed to the $2500 difference.
    Perhaps those who recently purchased can give us feed back to help us make the final decision.
    Bob
  5. #5
    Join Date
    Apr 2005
    Posts
    154
    Stray snuck his reply in while I was typing and has answered some of my questions - the 30% more powerful wheel motors and the second steering cylinder certainly make up some of the difference. Thanks
    bob
  6. #6
    Join Date
    Mar 2004
    Posts
    806
    N Central PA
    PT 422
    What advantage is there in having 2 steering cylinders??
  7. #7
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,810
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Welcome to TBN! [img]/forums/images/graemlins/grin.gif[/img]
  8. #8
    New Member
    Join Date
    Jun 2005
    Posts
    16
    Leesburg, VA
    None right now...
    Thanks for the welcome.
    Anyone close to Leesburg, Virginia with a 422 or 425? I'm pretty close to the MD and WV borders so it could be closer looking outside VA.
    -Phil
  9. #9
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    One of the cylinders is pushing. and one is pulling. Less effort is required. A larger single cylinder is required to do the same work.
  10. #10
    Join Date
    Apr 2004
    Posts
    88
    VA
    PT-425
    Hi Phil. Previous discussions on the differences were here and also here
    There have been no design changes to either model since these postings
    Good luck!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
