MountainJJ
Hello all, I have read as much of the forum history as I can and find this to be a great place and a great brand of equipment.
I recently acquired 10 acres in the Sierra at 4000'. Sloping property with a year around creek and about 8 acres in forest, mixed cedar, pine, fir and oak.
I have access to a Case 480 backhoe/loader and it does a ton of work quickly on the flatter areas. I have some areas that are truly over 100% slope, you can't even hike those. I have a couple of acres that are about 20 degree angle or less. that I would like to civilize with irrigation, fruit trees, grapes, garden, walking paths etc. Lots of fence to build and maintain and snow removal on about 250 yards of roads. Also the removal and burning of about 20 years of down wood and burnable (in the winter only up here) debris.
I have considered and driven several CUTs but they seem as unstable and potentially fatal on the slopes as the Case 480 is. All being narrow track with rather high COGs
My question to those of you that have seen or used these power machines is to help me understand the value and capability difference and make a choice between the 425 and the 1430.
The mix is that for the really heavy stuff on the flat I have a Case 480, but I still have lots of work to do on the steeper parts.
Your thoughts, recommendations, direction and links are all appreciated.
Thanks,
Thanks,
