Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jan 2004
    Posts
    685
    east TN
    Power-trac 422 January 2003 model
    Default Lift arms
    I lifted about 2 tons of moss out of my ponds last night. at the end of the session i kept hearing a swaking sound. This morning as i was greasing the center toggle and i saw grease coming out of a farily long crack in the center. Here the proble lay. I hooked up the buzz box and welded the centers back. I have heard some of you all have had this trouble. if mine gets any worse I'll be redesigning and re fabricating it.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Oct 2001
    Posts
    2,181
    Montana (Near Bozeman)
    PowerTrac 425 (September 2003)
    Default Re: Lift arms
    I ended up sending the center pivot pin back to PowerTrac and they beefed it up and I have not had a problem since.
    Mine cracked when using the mini hoe in a major project.
    PJ
  4. #3
    Elite Member KentT's Avatar
    Join Date
    Mar 2005
    Posts
    2,548
    Sevierville, TN
    Power Trac PT 425
    Could we see some pics of exactly where the crack was? Having just bought a mini-hoe, I'm concerned about where/how it is stressing the lift arms...
    I'm just learning how to use it, and wondering what is the least stressful way to get the job done... and what areas to monitor for signs of stress.
  5. #4
    Join Date
    Oct 2001
    Posts
    2,181
    Kent,
    A little background. I noticed when using the mini hoe that the pivot center pin was starting to leak grease on one end (not the middle). I kept using the mini hoe on a major project but called a welder to weld the crack on the end. This helped for some time but again after using the mini hoe for a number of hours that this time I was gettiing grease out of both ends of the center pivot pin.
    As I was unable to get the pin out, I sent the entire lift arm assembly to Tazewell and they repaired with a heavier center pin and so far I have not had any problems.
    PJ
  6. #5
    Join Date
    Oct 2001
    Posts
    2,181
    Shows broken center pivot pin, both sides.
    PJ
    Attached Images Attached Images
  7. #6
    Join Date
    Oct 2001
    Posts
    2,181
    Close up of one crack.
    PJ
  8. #7
    Join Date
    Oct 2001
    Posts
    2,181
    Final shot of other side.
    PJ
  9. #8
    Join Date
    Jan 2004
    Posts
    685
    east TN
    Yes, That is where mine was starting to giveway before i welded it. Some time when you get time send us some pics of PT's repair. All i did was reweld with several passes. I guess we'll see later on how long my repair works.
  10. #9
    Veteran Member FOURTEEN's Avatar
    Join Date
    Jan 2004
    Posts
    1,028
    Efland - Triangle of North Carolina.
    2004 Power Trac PT-425
    <font color="red"> [img]/forums/images/graemlins/blush.gif[/img] Same failure!
    Not a difficult repair! You can grind out the old pin, but have a good welding shop properly weld the new pin into place!
    Power Trac has beefed up the toggle!
    Check out my repair at PT-425 PROS &amp; cons?? #584022 - 02/12/05 !! </font>
    [img]/forums/images/graemlins/cool.gif[/img]
  11. #10
    Join Date
    Mar 2005
    Posts
    2,548
    Sevierville, TN
    Power Trac PT 425
    Thanks, PJ. Those are quite helpful, since I now know what areas to keep an eye on...
    A failure like that would certainly put you out of commission for a few days!
    As I said, I'm just learning to use the mini-hoe, and one of the "good habits" I'm trying to build is using the bucket curl for digging, and not really using the downforce of the lift arms for pushing the bucket into the ground. I'm still trying to understand the best "setting" for the tilt -- other than tilted enough to see the bucket underneath the QA plate.
    I have found that a little tilt of the hoe downward at the same time I curl the bucket seems to work well to fill the bucket -- kind of a scooping action toward the machine. But, I wonder what stress this is putting on that pivot pin...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
