y
Treadle Pedal Troubles
   / Treadle Pedal Troubles #1
tracdoc
western WA
sold PT-425
Well, 2 hours into my mowing yesterday I was just cruising along when all of a sudden I lost reverse. I pushed the forward treadle and that was gone, too. With the PTO and aux PTO circuits working fine, I conjured up some awful scenarios of tram pump failure. It was 6 PM. So I shut down and left the PT outside where she stopped.
This morning, I called Terry at PT, and while we were talking I mentioned that the pedal action felt somewhat soft and floppy. He had me pull the covers in the wheel wells to inspect the treadle. Lo and behold, the brass retaining pin, while holds the treadle pedals up and provides an axis of rotation, had fallen out. The 1st attachment shows a screwdriver pointing to the pin after I lifted the treadle and simply reinserted the brass pin. I started her up and treadle action was normal and locomotion was restored.
Next question to Terry (since the manual shows zip on this) was why did the pin fall out and what should secure the pin? In the next post, the attachment shows screwdriver pointing to a conical depression on the top of the aluminum block housing said brass pin. At the bottom of that depression is an Allen set screw (2.5 mm). Actually, there are two set screws, one stacked on top of the other. Terry instructed me to simply remove the top set screw, and then tighten the lower one against the pin. Once tight, back off quarter to half turn, and then re-insert the top set screw tightly to act as a jam screw against the lower one.
Easier said than done. The straight hydraulic connector exiting from the treadle valve over the depression prevented me from getting to the Allen screw with a standard L-shaped key and every other type of 2.5 mm Allen I have. Nothing I had was short enough. I guess I could have removed the hydraulic fitting, and bled the system afterwards. However, now I was on a mission. Using a hacksaw, I cut half the length off the “L” of the Allen key. Now it fit just fine, but as I backed off the screw, the key again got in the way of the hydraulic fitting. At that point, I used a needle nose pliers and inserted the cut segment from the Allen key into the screw and finished removing it, one tiny turn after another.
I found the bottom set screw to be quite loose. I tightened it as Terry instructed, and the re-inserted the jam set screw in reverse manner using the same “tools.” Once secure, I dripped 2 drops of GREEN Loctite in the conical depression and it was sucked into the threads, securing them.
I don’t like the conical depression. It was full of ‘gradoo’ and the top set screw was lightly corroded when I found it. You couldn’t actually tell it was a set screw until I cleaned it out with a toothpick. To minimize this, I filled the depression with heavy silicone grease to act as a barrier.
Thought I would share this with my fellow PTers since this forum is definitely the master service manual for our machines
Here is a pic showing a screwdriver pointing into the conical depression where the stacked Allen set screws are inserted
   / Treadle Pedal Troubles #3
Thanks for sharing, now I will have to check my machine out to see if I have this type of set up.
PJ
   / Treadle Pedal Troubles #4
Thanks for the tip. Glad it wasn't a serious problem I hope I can remember that if it ever happens to me before I get all excited over something simple but even if I do when I get it figured out it will still be a big releif not to have a big repair bill. Again thanks
   / Treadle Pedal Troubles #5
Thanks for sharing the information with the illustrative picture. Your right, the manual should be rewritten not very informative for an elite group that chooses to do there own wrenching or maintenance. I have already started compiling certain threads off of this site for the purpose of supplementing the manual.
If everyone took the time to snap a few pic’s along with there repair we could make our own repair manual. Of course this is hard to do when you are in a hurry to get back to the task at hand. Glad it was nothing major nice way to resolve the problem.
2014 International Derrick Digger Truck (A55973)
2014 International...
2015 VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
2015 VOLVO A25G...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
