3 Way 2 inch receiver
   / 3 Way 2 inch receiver #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Today I welded three two inch receivers to a quick attach plate. I used one that is 12 inches long and it sticks straight out. I made it longer so I could see the ball when attaching to the trailer. The other two are six inches long and one goes up and one down.
See attachment
Bob Rip
Pardon my welds, but I have never taken a class, just read a book.
I hope this is strong enough. I did not put any reinforcing brackets, hoping that the three receivers would reinforce each other. What do you think?
I did not realize it while designing this, but the top receiver makes a good storage place for attachments not in use.
Now I need to come up with some other attachments with two inch receivers. Any suggestion?
I have attached anther picture that is a little closer view.
Bob Rip
   / 3 Way 2 inch receiver #3
I would add some 1/2 in gussets to the top and bottom of the 2 in receiver. 4 in triangle should work fine. What is the purpose of the bottom receiver? You could put a ripper in there, or a pipe puller. The top receiver could be used for a goose neck trailer. A log splitter assembly could be used in the front receiver. You might get 400 to 500 lbs load holding capacity.
I will add some gussets. Do you mean 1/2 inch thick. Wow! I have some 1/4 plate. Is that enough? Also do you mean connect the middle receiver to the top and bottom receivers with this gusset?
I was thinking that the bottom receiver would be good for a root or dirt ripper. I have some old brush cutter blades. I was considering using one of them, cut short to 18 inches or so. How does this sound?
Bob Rip
   / 3 Way 2 inch receiver #5
Here is a picture of a receiver hitch that I made in welding class. I used a 1/4" gusset and square tube on mine cuz that is what I had available.
Looks like you have a pretty neat setup. Place to stow one receiver while you are using the other, neat! /forums/images/graemlins/grin.gif
   / 3 Way 2 inch receiver #6
Great job!
I'd like to make one of those someday.
P.S. since we are on the topic of trailer hitches and balls, I've found that you can use the middle claw and tooth of the grapple bucket to move a trailer/ equipment that has a pintle hitch. /forums/images/graemlins/cool.gif
</font><font color="blue" class="small">( Here is a picture of a receiver hitch that I made in welding class. I used a 1/4" gusset and square tube on mine cuz that is what I had available.
: )</font>
Jim, your receiver hitch was where I got the idea for this one. Thanks for idea.
Bob Rip
P.S. since we are on the topic of trailer hitches and balls, I've found that you can use the middle claw and tooth of the grapple bucket to move a trailer/ equipment that has a pintle hitch. /forums/images/graemlins/cool.gif )</font>
<font color="blue"> </font> I wonder if that would work on a ball type hitch. It seems it might do some damage. The pintle looks a lot tougher.
Bob Rip
   / 3 Way 2 inch receiver #9
Bob,
Going back to my "Meet Kermit" thread, it looks like you've combined the best of the ones PJ and I have built. I've found lots of uses for mine. I've since decided that a pair of sideways receivers to the right and left will also be useful, mostly for ditch and bank implements. Maybe one of these days I'll actually weld them on... /forums/images/graemlins/tongue.gif
Gravy
   / 3 Way 2 inch receiver #10
</font><font color="blue" class="small">( Jim, your receiver hitch was where I got the idea for this one. Thanks for idea.
Bob Rip )</font>
Coooool!
Nice improvement /forums/images/graemlins/grin.gif
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
2022 John Deere 5055E (A60462)
2022 John Deere...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
(APPROX. 20) 4' X...
