Results 421 to 430 of 457
06-27-2007, 06:33 AM #421Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Re: Build A Backhoe For PT425... It Could Happen
David, On using the fittings, I am using 90 degree fittings when I can. I am using straight fittings on the cylinder side of the valves, and attaching hydraulic lines that have a built in 90 JIC. I know that you are using three joystick, but I thought that I would use electric valves on the outriggers, and using toggle switches for control..
Originally Posted by MossRoad
Maybe, that 0-ring on the power beyond is a little tight. I will try again.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
06-27-2007, 11:04 AM #422Elite Member
- Join Date
- May 2005
- Posts
- 2,608
- Location
- Port Angeles WA
- Tractor
- Jinma 284 delivered 06/28/05
JJ, I have also been going thru this exact process, buy or build... I was looking at that laser cut parts kit from the guy in Canada. Could you tell me how thick the steel is that is used for the boom swing pivot plates? Those parts pre-cut would seem to me to really speed up the time involved in fabrication and might just be worth the price if I could adapt the boom pivot area to the frame mount I have in mind for my tractor. Could you also tell me how far apart the boom pivot base plates are spaced vertically? Do yo have any pictures of that boom pivot area on your project?
Originally Posted by J_J
ThanksLast edited by RonMar; 06-27-2007 at 11:52 AM.
Ron
06-27-2007, 05:40 PM #423Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
Here is just one picture of the spindle just welded together. The thickness is 3/8, or 1/2 in
Originally Posted by RonMar
J.J.
Git er done.
06-27-2007, 08:47 PM #424Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,708
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
J_J,
I'm using 90 degree fittings on the cylinders and straight fittings on the hoses. Pretty funny... two ways to accomplish the same thing.
As for the third valve VS the electronic soleniod valves, if I add a thumb I will either do that or use a manual diverter valve to switch between outrigger and thumb control.
06-28-2007, 03:39 PM #425Elite Member
- Join Date
- May 2005
- Posts
- 2,608
- Location
- Port Angeles WA
- Tractor
Thanks JJ, that was just what I was looking for. I kind of like the way the plates setup the outrigger angle. I will have to look at that guys website again. I think his parts kit is around $999, but it shure would save a bunch of fab time. Are you still working on the plumbing or have you got to use it any yet? I would be interested to hear how it works for you.
ThanksRon
06-28-2007, 05:05 PM #426Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
Every thing is welded together, and I just received the joystick valves. I plan to use two joystick valves , and two electric valves in my setup. I am also thinking of using two hyd sources. PTO, and the Aux circuit.
J.J.
Git er done.
06-28-2007, 05:20 PM #427Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
J.J.
Git er done.
06-28-2007, 05:32 PM #428Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
David, Check out this statement of the power beyond valve. This might change my thinking on some things. For instance, it seem like with a power beyond plug installed, the fluid flows through both valves until you activate upstream position . What happens when you are using the bucket, and you want to lift at the same time. Will the second function still work, or does it have to wait till the stick is back in neutral? According that statement the up stream valve has priority. What say you?
POWER BEYOND (HIGH PRESSURE CARRYOVER): A sleeve attachment which permits the oil flow from one valve (when in neutral) to be used by another valve downstream. Hence, a 3-spool valve could be connected to a 2-spool valve to create a 5-spool valve, The first valve takes priority and must have a separate outlet port to return oil from an activator back to the reservoir.J.J.
Git er done.
06-28-2007, 08:17 PM #429Elite Member
- Join Date
- May 2005
- Posts
- 2,608
- Location
- Port Angeles WA
- Tractor
JJ
Spool priority will be a drawback of using a simpler open center valve with power beyond configuration. One valve operation at a time with the upstream valve having priority.
That is the advantage of using a parallel ported valve for the hoe. If I understand it correctly, when you operate a spool on a parallel ported valve, it diverts fluid to the circuit you are working on and into a parallel buss/dead end manifold. Any other spool you operate will not be able to draw fluid from the main manifold as the first spool has diverted it already. But as you move the lever, that spool will connect to the parallel and share the fluid that the first spool has sent there.
Now if the two valves individually have parallel ports internally, then all the spools on that valve can share the flow. But since the parallel gallery isn't connected between the two valves, only the main gallery via the PB port, the second valve will be deprived when any of the spools on the first valve are used.
I was thinking of getting another 2 spool open center to go along with the one I already have extra for my hoe project(save me a few $) and this will be a drawback. But my pump output is only about 5.5GPM, so how much sharing could they really do?Ron
06-28-2007, 09:08 PM #430Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
Thanks
That is the reason that I was going to use the Aux circuit hydraulics on the second joystick valve, and my electric valves on the stabilizers.J.J.
Git er done.
