Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    DHS
    DHS is offline
    Join Date
    Jul 2003
    Posts
    172
    Watertown, SD
    PT-422
    Default Tiller seal replacement
    My tiller hydraulic motor developed a leaking seal by the shaft. The motor shaft is mounted to a threaded 8 inch cylinder that goes over and attaches to the tiller shaft. Removing the cylinder from the tiller tyne shaft was easy. I have been unable to remove the cylinder from the shaft of the hydraulic motor.
    Has anyone replaced their tiller motor seal and do you know the procedure for removing the cylinder?
    Thank-you,
    Dale
  2. #2
    Elite Member BobRip's Avatar
    Join Date
    Sep 2004
    Posts
    4,036
    Powhatan Va.
    2000 Power Trac 422
    Default Re: Tiller seal replacement
    I have removed the motor from the trencher. Maybe it is the same. Look for my post on that or send me a picture of your tiller.
    Bob Rip
  3. #3
    DHS
    DHS is offline
    Join Date
    Jul 2003
    Posts
    172
    Watertown, SD
    PT-422
    BobRip,
    I looked at your trencher post and I believe the connection it is similar to my tiller.
    Dale
    Attached Images Attached Images
  4. #4
    DHS
    DHS is offline
    Join Date
    Jul 2003
    Posts
    172
    Watertown, SD
    PT-422
    BobRip,
    The is another picture looking down the barrel of the beast. I ordered the seal kit and bearing from PT. They will loan me the tool to extract the nut.
    Thanks for your advice,
    Dale
  5. #5
    Join Date
    Sep 2004
    Posts
    4,036
    Powhatan Va.
    2000 Power Trac 422
    Yes, it looks the same. If you call Terry at Power Trac, they will loan you a special castellation socket. They have these custom made. They charge it to your credit card, and when you send it back you get credit. You pay shipping both ways.
    Bob Rip
  6. #6
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Bob, When you get the nut off the shaft, please take a close up picture of the nut. I can't see the nut in the picture. I am just curious. I have a 6 ft tiller also, for my 1445.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  7. #7
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    Before they changed the program, when you sent a reply , the title had the persons ID in the title. Now, if you don't use Quote, and you do not use their ID in the reply, It is hard to know to whom you are replying. Is there any other way to reference the post? Maybe use the post #? I usually try and use the persons ID in all my post. If I knew all the names, I would use them.
    J.J.
    Git er done.
  8. #8
    Veteran Member Spiffy's Avatar
    Join Date
    Apr 2005
    Posts
    1,179
    SD
    PT2445; several ag machines and classics
    If it follows the stump cutter - i.e. 4XX has a straight shaft, while my 2445 has tapered - you should be alright there, else you may want to have a press handy too.
    I put a seal kit in my PHD recently and it's not too bad of a job.
  9. #9
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    20,697
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Test reply to J_J using the quick reply button to the right of the quote button.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  10. #10
    Join Date
    Aug 2001
    Posts
    20,697
    Quote Originally Posted by J_J
    Test reply to J_J using the quote button.
    MossRoad
    Of It In Action!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
