Mini Modification
   / Mini Modification
KMA said:
It was 1/2" round, 36" long cold rolled steel I believe. I got it at either Lowe's or Home Depot (can't recall). I grinded the last few inches of the end flat to match up with the stock part. Essentially, I tried to make the end look as much like the original part as possible.
That's very helpful. Thanks.
   / Mini Modification #32
   / Mini Modification
Welcome back. Have you made any recent modifications that we don't know about?
   / Mini Modification #35
Hydraulic Tank Temperature Gauge
   / Mini Modification
Would that work on the engine as well? It looks like you have room for two guages.
   / Mini Modification #38
MossRoad said:
That's pretty slick. Can you give us some more info on the guage and the sensor?
Taylor battery operated panel mount with remote sensor. The sensor is inserted in a well near the middle of the tank
sg
   / Mini Modification #39
Ordered a Tiny Tach commercial model for the other side. The Tiny tach would not work at all with the Kohler engine. I was looking for a multi function gauge that you could switch between sensors ( CHT, EGT and Tank Temp.) Had to settle for the Taylor thermometer. The Tiny tach people told me they were working on a cylinder head temperature gauge I do not know the status of that.
sg
   / Mini Modification #40
Clarke,
What is the highest hydraulic temperature you have seen. What was the outdoor ambient temperature at the time.
Duane
Sweepster PTO Driven Sweeper (A47477)
Sweepster PTO...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
ITEM LOCATION (A53084)
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
