Results 21 to 30 of 30
03-22-2007, 03:43 PM #21
- Join Date
- Jul 2006
- Posts
- 5,575
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
Re: Who has a Tiller Atatchment, Opinions?
Box Blade. On a normal 3pt you can adjust the shackle to tilt the boxblade. good for first drafts on roads and such... But all 3pt adapters I looked at, and most of the powertrac toys, do not seem to have tilt built in. Someone was going to try and make a PT adapter with a tire rim to create tilt. Never heard if that happened...
Anyway, it is to tilt the box blade. Lackendar added a couple of attachment point above and below the level point to allow angle work...
03-22-2007, 04:11 PM #22
03-22-2007, 05:16 PM #23
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Originally Posted by AltavistaLawn
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
06-16-2007, 05:45 PM #24
- Join Date
- Apr 2005
- Posts
- 154
- Location
- Atascadero, California
Originally Posted by woodlandfarms
06-16-2007, 07:08 PM #25
- Join Date
- Jul 2006
- Posts
- 5,575
- Location
- Tractor
Here are some pix. They are not very good and I am not at the tractor until the end of the month... I am sure Ken will get you better pix before I get to...
That price quote has to be wrong, unless Steel has gone through the roof. I think mine was $425 plus $65 for the adapter plate... And cause i bought so much from him he reduced the pricePower-Trac 1850, grapple, hoe, 90" mower, 72" box blade
06-16-2007, 10:29 PM #26
- Join Date
- Dec 2006
- Posts
- 2,314
- Location
- South of Rochester, NY
- Tractor
- Power Trac 1850, NH 2120
Unfortunately, I just dropped mine off a couple of hours ago to a local welder to have the attachment plate removed and the correct one put on at the correct angle. This was the first one Lackender made for this size tractor and he made a mistake when fabricating the plates. Fortunately, i caught the mistake before Woodland Farms had his shipped. A friend was going to weld mine but he has been recovering from knee surgery and having a rough time of it. I finally could not wait any longer so I gave it to the local welder. I have a couple more attachments that need to be corrected as well.
Ken
06-27-2007, 11:21 PM #27
- Join Date
- Nov 2004
- Posts
- 172
- Location
- Thayer, MO
Originally Posted by ernemats
I have finally settled on the clearance technique of stopping the tiller then lifting it and rotating it upside down. I then bounce/jounce the arms a few times until I see the tines move freely. I was having to stop every 25-50 feet to clear the rocks by hand and I got tired of turning off the tractor, dismounting, clearing the rocks and starting up again.
I think the tiller works better if you connect the hydraulic hoses so the tines dig from the bottom up instead of conventionally top down. Land Pride makes BOTH kind of tillers and they recommend bottom up.
On Monday a friend showed me an old walk behind Sears tiller from an auction that digs bottom up. He says it is the best small walk behind he has ever used and he wouldn't go back to the conventional style for anything. When a tine catches a rock on the way up it tends to pop it out. When it hits a rock on the way down it tries to pound the rock downward through the hard base underneath.
06-28-2007, 09:22 PM #28
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
Originally Posted by BAGTIC
This will also work using the auger. If it gets jammed, reverse and pull out.J.J.
Git er done.
07-02-2007, 05:02 PM #29
- Join Date
- Dec 2005
- Posts
- 50
- Location
- No. California
- Tractor
- PT-425
Originally Posted by J_J
07-02-2007, 07:40 PM #30
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
Originally Posted by hogi
If the tiller hydraulic motor is bi rotational, then you can plumb in the valve below. It will detent in three positions. All you really have to do is plumb the valve into the circuit for the PTO. Once installed, this is how it should work. The hydraulic lines for the tiller would be connected into the quick disconnects that are now on the selector valve. You then flip the switch for the the PTO, and the hyd fluid is sent to the new valve. In the neutral position the hyd fluid is routed back to tank. In the forward detent the tiller will till in the normal way. If it becomes jammed on a rock, just pull the valve handle back to neutral, and then pull the valve handle back to reverse the tiller.
Caution.
This maybe a safety issue some how. Pt might be worried about the tiller slinging debris back toward the operator.
One of the guys said that Terry said that the tiller motor was not reversible. If this is true, then there is no fix, except to replace the tiller hyd motor with a bi rotational hyd motor.
Surplus Center Item DetailLast edited by J_J; 07-02-2007 at 08:01 PM.
J.J.
Git er done.
