HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-20-2008, 12:07 AM   #191 (permalink)
Default Re: Members home made attachments / improvements
Hey!!...Where are all the creative minds out there???? I just noticed the number of hits this thread has had. It's bouncing back & forth with MR's backhoe thread. 30,ooo...plus views but not too many pictures of PT custom attachments, Mods, or Improviments...Whats up with that??
Rivco is offline   Reply With Quote
Old 04-20-2008, 08:58 AM   #192 (permalink)
Has anyone come up with a good solution for the crappy, plastic, non castered rear mower wheels?? My brush mower with the Caroni caster wheel kit worked great...after I installed a smaller, solid rubber caster tire.
Old 04-20-2008, 09:06 AM   #193 (permalink)
Gold Member
Tim_in_CT's Avatar
Quote:
Originally Posted by Rivco
after I installed a smaller, solid rubber caster.
what was wrong with the pneumatic tires that you installed initially?
__________________
Now in Annapolis, MD.
2005 PT-422
4n1 bucket, minihoe, auger, 48" mower, land pride aerator, tow adaptor, forklift, crane, M1 abrams turret.
PT422 (6/23/05) photo page
Tim_in_CT is offline   Reply With Quote
Old 04-20-2008, 09:16 AM   #194 (permalink)
Quote:
I had a clearance problem. The larger pneumatic tires would sometimes hit and rub the PT front tires. When I installed the Caroni kit I had to move the mower attachment plate bracket back 5" to extend the mower further from the PT for clearance.
Old 10-29-2009, 09:58 PM   #195 (permalink)
Hey I'm bumping this to the top again. It's been a long time since anyone has posted pictures of any custom PT attachments or improvements. Winter is coming and I love to see the creativity flowing
Old 11-06-2009, 11:19 PM   #196 (permalink)
In relation to the title of this post I am working on making a useful tool out of this for my PT 422. Somewhat of a challenge but I gave a song for it and have use for its lifting height. 14 ft and 4000 lbs at the forks. Granted I wont lift the full weight but I want the height for a man lift.
stray is offline   Reply With Quote
Old 11-07-2009, 07:36 AM   #197 (permalink)
Super Member
IslandTractor's Avatar
Quote:
Interesting with great potential. I'd be a bit concerned about counterbalance though, especially with a PT. How do you PT guys deal with adding ballast given the lack of 3pt attachments and small wheels (not worth loading I'd guess)?
IslandTractor is offline   Reply With Quote
Old 11-07-2009, 08:27 AM   #198 (permalink)
J_J
Super Member
J_J's Avatar
The safe lifting capacity on the Power-Trac's is figured from the side loads on the wheel motors, the size of the cylinders, the angle they are mounted, and the distance the load is from the pivot point. Any more weight than that is called the pucker factor.
Although we could add extra weight to the rear, and therefore lift a greater weight than advertised, it is not advisable as the hydraulic wheel motors were not designed to work with greater loads. Shaft seals will start to leak, etc.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 11-07-2009, 08:32 AM   #199 (permalink)
J_J
Super Member
J_J's Avatar
What was the original purpose of the yellow attachment. I am guessing , a 3ph attachment to lift hay bales or rolls. How much weight do you think it will lift.
Did you put a QA on it ?
I re-read and saw the 4000 lbs. Do you think those wheels will handle 4000 lbs?
__________________
J.J.
Old 11-07-2009, 12:48 PM   #200 (permalink)
That's a great idea !!. Some of you might remember... I built a hydraulic boom lift that had a lift HT. of 12'. I added caster wheels to the frame...very similar to your picture. You have built some great custom attachments in the past so I'm looking forward to seeing pictures of the completed man lift.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.44410 seconds with 9 queries
