Page 27 of 38 FirstFirst ... 172425262728293037 ... LastLast
Results 261 to 270 of 378
  1. #261
    Veteran Member Barryh's Avatar
    Join Date
    Jul 2005
    Posts
    1,403
    Harpers Ferry WV - Mountains of Shannondale
    Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
    Default Re: Members home made attachments / improvements
    Quote Originally Posted by Kent View Post
    OK, two more pictures.
    Basically the design is two square tubes welded onto an attachment plate. Cross members provide a rigid frame and are lined up with rungs to attach with u-bolts. There are also size dogs made out of bent angle iron to provide support under the ladder rungs when it transitions from the hanging state (carried by u-bolts) to the upright state.
    The guy who did the welding suggested the stuts and the flat bars going forward/backward to increase the rigidity and take tension off of the leading weld on the attachment plate. I can say this was a great idea given how much flex those long ladders have anyway! Lots of bounce when driving it around...
    I can leave the carrier attached when the ladder is in use, and can detach the whole thing without undoing the u-bolts. The only trick is that the ladder has to be at least about 30 degrees up at one end to detach/attach, as the PT loader cannot curl its attachment plate forward past horizontal/down.
    Very innovative Kent I like it..
    Barry
    __________________________________________________ _____
  2. #262
    Gold Member 3238dpw's Avatar
    Join Date
    Nov 2006
    Posts
    348
    Central NJ
    Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
    Default
    Quote Originally Posted by Tim_in_CT
    That is pretty cool, but not $594 cool.
    Plus, I suspect you would lose some stability when you chucked it up in the PT 2" receiver.
    I strongly considered fabbing something like that when I was cleaning my gutters at the top of a 24' ladder last fall. Instead, I just made a 15' PVC wand that attaches to my leaf blower, and finished the job from the ground.
    Lets see that wand and how you attached it to your blower
    Scott
  3. #263
    Silver Member BKBoiss's Avatar
    Join Date
    Nov 2013
    Posts
    240
    Slave lake AB Canada
    Members home made attachments / improvements-image-jpgMembers home made attachments / improvements-image-jpg My counterweight and brush forks. I use the forks probably 90% of the time, they are light enough I can pick them up with one hand and the abuse they take really surprised me. So far I've only bent the tines a little but that was using them as a pry bar with the loader to free up some frozen logs.
  4. #264
    Join Date
    Jul 2005
    Posts
    1,403
    See my old thread is still here as well.. May have to get another one of these little Pt monsters soon.
    Barry
  5. #265
    Join Date
    Jul 2005
    Posts
    1,403
    Before there was Power Trac .
    https://www.youtube.com/watch?v=9kThwwwp6WA
    Barry
  6. #266
    Join Date
    Jul 2005
    Posts
    1,403
    Power Trac wants close to $700.00 delivered for a new Rop's.
    I figure since I have an old tractor anyway I will make my own and cut that price in half.. Figured I may as well put it under this old thread I started years ago. My question to any of you has anyone already done this ? And would one of you be nice enough to measure out from the side mount of your Rop's to the edge of the outer bar. I would appreciate it.. I was thinking around 6 inches extended out on each side. Thanks in advance ..
    Barry
  7. #267
    Gold Member
    Join Date
    Sep 2005
    Posts
    346
    Poconos, PA
    Power Trac 2425
    mine is welded right to the frame.....so it only extends the width of the 2" pipe on each side........Jack
  8. #268
    Join Date
    Jul 2005
    Posts
    1,403
    Thanks Jack !
    Barry
  9. #269
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,258
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Not at home right now... don't know if this picture from the front will help you or not, but it can't hurt!
    Members home made attachments / improvements-pt425viewfront-jpg
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  10. #270
    Join Date
    Jul 2005
    Posts
    1,403
    Yes it does on the angle thanks ..
    Barry
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
