HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-11-2007, 09:39 AM   #21 (permalink)
Super Star Member
MossRoad's Avatar
Default Re: Members home made attachments / improvements
Thanks J_J.
Now I am wondering about the necessity of the linkage. I mean, really, what's the point of it? I would suspect leverage and the ability to move the bucket past the line where the cylinder ram would rub the end of the dipper, but if you just used taller brackets on the bucket like that last one you show, I can't see a reason for the linkage. Please edjumacate me on the need for linkage.
__________________
MossRoad
Click On My Little Tractor
To See Pictures And Videos
Of It In Action!!!
MossRoad is offline   Reply With Quote
Old 05-11-2007, 10:10 AM   #22 (permalink)
Barryh's Avatar
Quote:
Originally Posted by MossRoad
Thanks J_J.
I'm interested in this one too, as I plan to do a simple mini hoe along the lines of your fork lift hoe creation, just using square extension tube that plugs into a trailer hitch... For me the simpler the better. I'm not as interested in speed, as much as open / closing strength.
__________________
Barry
__________________________________________________ _____
When I was younger I used spend my time jumping dirt hills. These days I find it much more fun to level them.
Kubota BX-1500 woods crawler / old mans ATV.
Barryh is offline   Reply With Quote
Old 05-11-2007, 01:09 PM   #23 (permalink)
J_J
Super Member
J_J's Avatar
Thanks J_J.
David, Barry
The linkage is designed for buckets that have the ears below the level of the boom. If you have a certain bucket design, as in the picture, you would not need a linkage. If you look at many different buckets like I have, they don't seem to have any set design. In my opinion, the linkage is there to allow the bucket to roll over past the horizontal line. Some people might want 180 degrees of curl, and that also lets you stow the bucket for transport. Just enough curl to hold dirt in would be enough, and if you add a grapple in the vertical position, that would work good. So my final opinion would be 180 degrees of curl is good, but 90 degrees will work also. This logic will dictate the bucket you buy or build, and whether you want to use linkage. It is desirable to have as straight a push as possible. The distance between the ears should be as small as possible, so you don't bend the bolts or rods holding the bucket.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 05-11-2007, 01:20 PM   #24 (permalink)
J_J
Super Member
J_J's Avatar
Quote:
Originally Posted by J_J
David, Here is a picture of a mini-hoe that doesn't use any brackets.
The bucket just has large ears. Looks very sturdy.
I believe this Mini-hoe belongs to someone on the PT forum. If they read this post, my question would be, did you build this bucket or buy as is?
__________________
J.J.
Old 05-11-2007, 02:40 PM   #25 (permalink)
J_J
Super Member
J_J's Avatar
Quote:
This bucket has three sets of holes for different applications. It would still need some roll over brackets.
File Type: jpg 41465%20-%2012in%20Bobcat%20331%20bucket.jpg (77.6 KB, 564 views)
__________________
J.J.
Old 05-11-2007, 03:14 PM   #26 (permalink)
woodlandfarms's Avatar
Quote:
Originally Posted by KentT
Wow, that first picture of the grapple-hoe looks like a monster...
How much weight can you pick up with it without experiencing PT pucker?
I'd like to find an affordable way to make a "tree/shrub scoop" -- I have plenty of little saplings I'd like to transplant...
There is a great and very simple plan on the TBN site that I am thinking about building as I am a beginner welder. Look around and you will find the plans, if not PM me and I will email them to you.
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is offline   Reply With Quote
Old 05-11-2007, 06:03 PM   #27 (permalink)
Barryh's Avatar
David, Barry
Here's the bucket I'm buying, if you scroll down to the 8 inch version. It has ears so it shouldn't need any linkage? Lackender Skid-Loader Backhoe Pricing
I'm not worried about transport as I will just take it off as a unit when I want to transport it. I only need just enough curl to dig three foot down, and hopefully I'll be able to see what I am doing.
__________________
Barry
Old 05-11-2007, 06:45 PM   #28 (permalink)
J_J
Super Member
J_J's Avatar
You are right. That bucket that I posted earlier, looks like a Lackender bucket. It would save on trying to figure out the correct linkage. A 4X4 , or a 6X6 in , 1/4 in wall tubing should do the trick.
__________________
J.J.
Old 05-11-2007, 06:54 PM   #29 (permalink)
Barryh's Avatar
Thanks, after I get the bucket, then I may get your advice on the correct cylinder, but more important the correct valve setup. That is if you don't mind me asking. I have a few cylinder's already picked out, but I'll wait until I get the bucket attached in the right mannor, then decide on the length of the tube. Then I can go from there.
__________________
Barry
Old 05-11-2007, 10:09 PM   #30 (permalink)
I have their backhoe. Nice peice of equipment (Thank you Ksimolo)
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.64856 seconds with 9 queries
