Skid Steer Quick Attach Adapter for Kioti KL120/KL130 (CK20-CK35) Loaders
Item Details
Make
Kioti
Item status
  1. Sold
I have a quick attach adapter for a Kioti KL120/KL130 loader for sale. This fits the Kioti loaders that come with a CK20,CK25,CK27,CK30,CK35. This enables the use of SSQA laoder attachments (buckets, forks, etc.).
The pin spacing it setup such that there is a slight increase in curl force to help makeup for the loss from pushing the bucket away. It is also offset a couple degrees to increase how far the bucket can curl back. This is very helpful when using forks or carrying a lot of material with the bucket near the ground.
It was made by Michigan Iron & Equipment in Morrice, MI and is less than a year old and was never stored outside (with my tractor in the garage).
I paid $400 for this, will take $250 firm. I'm in the Flint/Saginaw Michigan area but would be willing to drive a bit.
   / Skid Steer Quick Attach Adapter for Kioti KL120/KL130 (CK20-CK35) Loaders #2
Geez, if I was closer I'd buy it in a heartbeat.
Because i've been asked and I forgot to mention, it's for sale because I currently have two QA adapters. I would never go back to pin-on!
   / Skid Steer Quick Attach Adapter for Kioti KL120/KL130 (CK20-CK35) Loaders #4
I wish I was local. In the Northern tool catalog they sell the adaptor plate that I think goes on the other side of this setup and stays on the implement. I want to put a quick Change bucket on mine and wonder if I had this on one side and the other piece welded to my bucket it if it work ok.
Yes, that's exactly what I did with mine. Michigan iron sells the QA plate for the implement side (and I believe includes a template to help you align it), or you can have them weld it to your bucket for you and paint it.
Sold!
