1952 ford 8n the lift works when it wants to. what can i do
   / 1952 ford 8n the lift works when it wants to. what can i do #1
jimmy patrick
LELAND NC
1952 FORD 8N
same as th title.
   / 1952 ford 8n the lift works when it wants to. what can i do #2
Welcome from Oklahoma. You might want to post this under "Owning/Operating" with some information, such as when did it start doing this, is it only when machine is cold, if you've changed fluid, etc. With no information given you'll have a harder time getting food information in return.
Ken
   / 1952 ford 8n the lift works when it wants to. what can i do #3
as you know, the pto must be operating for the hyds to operate.
if the oil is milky and dirty, the control valve can stick.
if you remove the round cover where the dipstick is, there is a long rod from t he top cover to the pump. as you move the 3pt lever, this rod moves the control valve ina d out of hte pump. if the oil is gritty and dirty, the valve may not move fully in or out.
post back some more info
   / 1952 ford 8n the lift works when it wants to. what can i do #4
Welcome to TBN :)
I moved your thread to the Ford Vintage Tractors forum.
