tn90f quitting all of a sudden
   / tn90f quitting all of a sudden #1
blue tractor
Ontario
tn90f
Hi I have a TN90F that is quitting all of a sudden, all lights go out? After letting it sit for a while it will start back up and lights work again. Thanks for your help with this! It is a great tractor, I use it for loader work, bailing,plowing,planting.
   / tn90f quitting all of a sudden #2
Bad connection on one end or the other of a battery cable? Particularly the chassis end of the ground cable.
Hi Rick
I checked all the battery terminals and chassis connection, they seem good and tight! Thanks Scott
   / tn90f quitting all of a sudden #4
If you didn't disconnect and inspect them, you don't know. It is the first, cheapest thing to do. I'm hearing that you looked at the connections and maybe wiggled the cables. Not enough.
