Larrycrosby
Shifting lever issue, it get stuck in 4th gear, for sure maybe others tractor new to me. We can pull cover off and reset it, usually it looks like the middle slider is stuck to one side, need to tap with a hammer to get it back in place. When looking at it from the bottom it looks like the lever is going to one side, an area that it should not be in. I believe this is all happening because things are warn a little to much, do not see anything bent at first look.
Looking for thoughts on how I can best fix the problem and a new casket for when the things is put back together.
Larry
Larry
