starter sounds like a big wind up toy??
   / starter sounds like a big wind up toy?? #1
Floyd, VA
MF 35
Went to crank my 35 and instead of the normal starting sound then ignition it sounded like something winding up then down really loud. Is my starter shot?
Thanks.
   / starter sounds like a big wind up toy?? #2
maybe your bendix is bad. Try removing the starter for a bench test. When jumped the starter gear should shoot out as it turns
   / starter sounds like a big wind up toy?? #3
Likely bad bendix as mentioned.
Could be missing teeth on the flywheel but thats remote.
Try wacking it with a hammer while starting, see if it engages.
And/or remove and bench test.
   / starter sounds like a big wind up toy?? #4
Thanks.
Bendix. Pull the starter and bench test. Bendix should move quickly toward the starter when 6V or 12V is applied to the starter solenoid.
Great, I'll start looking at that. Thanks!!
   / starter sounds like a big wind up toy?? #6
try taping it with a hammer [ not hard] while someone tries to start it. like what has already been mentioned.
   / starter sounds like a big wind up toy?? #7
Ford actually had a part # for a hammer to do that!
just kidding:laughing::cool:
Tapped with hammer, sounded like something was going to engage but didn't and I cranked and tapped for a while....guess I'lll take it off for further investigation.
   / starter sounds like a big wind up toy?? #9
Usually a good rap will free it up.
I bet the bendix isnt coming out all the way. You'll see it on your bench test.
   / starter sounds like a big wind up toy?? #10
Hey that's an old school hot rod trick. :grin: -kid
