Montgomery Ward Lawn Tractor tiller
   / Montgomery Ward Lawn Tractor tiller #1
wretheredge
Roosevelt, UT
I stripped a bearing on our tiller. I was able to take it apart and thought I would be able to put it back together without too much trouble. However, the housing will not fit back together, there is a gap. On one side there is a bearing and two spacers. You can tell that they are in the correct place on how they have worn. On the other side there is just the bearing. I have attached pictures. Any ideas how to put this back together?
   / Montgomery Ward Lawn Tractor tiller #2
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
   / Montgomery Ward Lawn Tractor tiller #3
Not trying to be a smart aleck, but if you leave it out in the rain anymore and don't dry it off, it's not going to be worth putting back together.
   / Montgomery Ward Lawn Tractor tiller #4
Incorrect bearings is my guess. From the picture I think the bearings you have are taller than the original. I assume you compared before install? Did you replace the sleeve as well?
