candersen10
- Joined
- Mar 27, 2007
- Messages
- 267
- Location
- Phoenixville, PA
- Tractor
- Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
I have a CT332 and am thinking about trading it in on a new 333E.
Has anyone run a 333E? If so, what are your thoughts? What sort of problems have you have with them? Can you answer any of the questions below?
- how is fuel consumption? Any better than the CT332?
- Does the foot throttle reduce fuel consumption much or do you run it flat out?
- Does the Yanmar engine seem like a reliable unit?
- Does the DEF fluid being used to meet Tier 4 emissions standards seem likely to pose reliability issues or create any headaches?
- How easy is it to access the engine/drivetrain components (on the CT332, the cab swings up nicely, but then you have to unbolt a ton of stuff to remove the cab floor - is this an issue with the 333E or does the cab bring with it the whole floor)?
- Does the Fan being on the rear outside of the radiator make it prone to getting broken etc? Does the heavy duty grill do much to reduce this risk?
- Has Deere done anything to reduce bushing wear on the booms? Are the bushings still held in place with Bolts - and if so, do these appear to come loose regularly (a frequent problem with the CT332)?
- Are there any must have options (I am thinking cab/ac, ISO pilots, high flow hydraulics with a regular flow hydraulic valve set as well, auto reverse fan, heavy duty rear grill, power quick-tach, two speed)?
Thanks and my apologies if this is in the wrong section or a topic of no interest to anyone else.
- Charlie
- Charlie
