Kyle_in_Tex
Super Star Member
I was told by a friend that some folks would weld a piece of tool steel to the front edge of their shredder blades for longer life.
I'm a machinist by trade, but not a "weld and fix it" repair type machinist.
Obviously I would be worried about it breaking off and go slinging. But if you properly prepped with weld bevels both the blade and the tool steel, then pre-heated, welded then post heated in an oven, How much do you think the quality of better steel would work?
The trick would be to keep the dis similar tool steel from cracking. Also, if you didn't quick cool it after welding to really harden it, it would stay relatively soft but still much tougher than the original blade. Maybe I need to re-think this and use a different tough metal like 17-4 Stainless or something else.
Comments?
Comments?
