Item Details
- Item status
- Sold
I bought this attachment a couple of years ago but have only used less than 8 hours. I've stored it in my pole barn and is in very good condition. I will not ship so local pick-up only. $3500.
I also have a 12" bucket that I had specially built but have never used. Sell with this attachment for an additional $375.
Here are the specs:
Taylor Way 766 Backhoe Attachment
This backhoe comes with a 16" bucket and a 3 point hitch mounting kit.
Features and Specifications:
* Works with 35-50 HP tractors with a Category 1 3-point hitch
* The tractor must have a rated lift capacity of 800-3,800 lbs. and up to a 5,000 lb. GVW
* The tractor must have a rated flow of 6-8 gpm
* Height with boom fully retracted is 5'8"
* Width with stabilizers up is 5'6"
* Ground clearance is 10"
* Overall length (including 3 point hitch bracket) is 8'1"
* Transport overhang is 3'7"
* Boom pivot height is 25"
* Operating weight is 1,067 lbs.
* Maximum digging depth is 6'6"
* Overall operating height (fully raised) is 9'7"
* Loading height (bucket at 60 degrees) is 5'10.75"
* Loading reach is 3'
* Reach from swing post is 9'5.25"
* Stabilizer spread in the operating position is 7'5.5"
* Stabilizer spread in the up position is 5'6"
* Reservoir capacity is 3.2 gallons
* Relief valve setting is 2,610 psi
* Uses Type-A non-foaming hydraulic oil
* Bucket cylinder digging force is 2,247 lbs.
* Dipper cylinder digging force is 1,300 lbs.
* Tooth wrenching strength is 3,300 lbs.
* Swing arc rotation is 140 degrees
* Bucket rotation is 170 degrees
Here are the specs:
