Results 1 to 2 of 2
  1. #1
    Platinum Member Zork's Avatar
    Join Date
    Dec 2003
    Posts
    780
    Virginia
    '04 Branson 3520, '51 Fergy, '96 MTD 18/46, '02 Craftsman GT5000/48
    Default Ferguson T020 gas tractor with loader, Virginia $2400
    Ferguson T020 gas tractor with loader, loaded rear tires, chains, and additional 3pt hitch weight: $2400 This is a working tractor and from what I can see just needs paint and a good home.
    The loader lift is hydraulic power up and gravity down (one way cyl), with rear weight assembly. The bucket is hydraulic power dump and hydraulic power curl (2way cyl).
    The tractor has a new battery, new belt, new intake/exhaust manifold, and new muffler and pipe. The starter and generator has been repaired. The tractor comes with a set of chains for the rear tires ($300 value) The loader is currently not installed and I have been using it in summer 2010 to mow approximately 4 acres of grass; FINISH MOWER IS NOT INCLUDED. Additionally, I have used it during the recent cold weather snows to clear my drive with the rear blade (REAR BLADE IS NOT INCLUDED)
    Photos can be seen here :Ferguson Tractor
    He who is full loathes honey, but to the hungry even what is bitter tastes sweet.
  2. #2
    Join Date
    Dec 2003
    Posts
    780
    Virginia
    Default Re: Ferguson T020 gas tractor with loader, Virginia $2400
    This loader appears to be manufactured by WAGNER. I believe it is a W3 model. I am willing to sell the loader apart from the tractor for $1000. The pump is powered by a shaft off the front of the engine; or according to diagram, from transaxle hydraulics. If I am correct, my research found that available documentation says it was built for Ford tractors and will fit 9N, 2N, 8N, NAA, 600, and 800 tractors. The front axle will have to be made wider.
    Here is a link to the loader
    Main Frame and Dipperstick Assemblies (3 pages)
    http://www.ntractorclub.com/forums/m...sages/789.html
    Attached Thumbnails Attached Thumbnails Ferguson T020 gas tractor with loader, Virginia 00-cover-20of-20manual-jpg   Ferguson T020 gas tractor with loader, Virginia 00-page-2007-20-20preparation-20of
Similar Threads
  1. John deere 52 loader
    By Dennisfly in forum John Deere Owning/Operating
    Last Post: 11-09-2003, 09:28 PM
  2. Ballast Ballast
    By JDGREEN4ME in forum John Deere Owning/Operating
    Last Post: 10-17-2002, 10:21 PM
  3. 70A loader vs. 52 model
    By fancsco in forum John Deere Buying/Pricing
    Last Post: 12-07-2001, 05:10 PM
  4. Replies: 92
    Last Post: 08-21-2001, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
