Results 1 to 10 of 11
05-21-2011, 05:48 PM #1
- Join Date
- May 2011
- Posts
- 27
- Location
- Olive Branch, MS
- Tractor
- Mitsubishi D1500 Ke85 engine
Want to buy - decent used small Kubota 17-20 hp
Anyone have a decent small kubota 17-20 hp for sale. I'm not too concerned about the appearance but would like a good starting and running engine with no oil leaks or usage. I would like the pto and lift to be in good shape. I'm in Northern MS, near Memphis but would be willing to travel 500 miles or so. Thanks!
05-21-2011, 05:56 PM #2
- Join Date
- Sep 2002
- Posts
- 3,038
- Location
- Washington
- Tractor
- B7100
Re: Want to buy - decent used small Kubota 17-20 hp
I'd suggest that you use Search Tempest which will search Craigslist in a radius that you specify.
SearchTempest - The EASY way to search Craigslist
05-21-2011, 06:16 PM #3
What are you looking to do? i.e. Loader Work, Mowing, Brush Hogging, Tilling, etc.? I would look into a BX or a B. The B's have larger frames than the BX's. I have a BX2230 (22HP) with an FEL (Front End Loader), Mid Mount Mower (60"), and a Woods Rotary Cutter and i love it. I imagine you are looking to buy a used one, searching online is great. You can also go to a local kubota dealer. Most have a good selection of new and used tractors. Good Luck!
2010 Kubota MX5100HST (50HP) 4WD w/ LA844 FEL Bucket, Unloaded R4's
2005 Kubota BX2230 (22 HP) 4WD w/LA211 FEL Bucket Unloaded R3's,60MMM, 4ft Woods Rotary Cutter
2006 Deere L110 42" MMM
1978 Wheel Horse C141 42" Blade, 42" MMM, and Wagon
15 Year Old
Member of the TBN "Young Gun" Club
05-21-2011, 06:18 PM #4
- Join Date
- Aug 2009
- Posts
- 5,715
- Location
- Beaver Creek, Northern Michigan
- Tractor
- Kubota BX2360
Barlows have a good supply of used tractors. Might check their website. They'd even deliver, on the next truck heading your way, I'd guess.
BP
"Some chickens, some gardens and a Kubota."
05-21-2011, 07:41 PM #5
- Join Date
- Nov 2004
- Posts
- 408
- Location
- Winnfield Louisiana
- Tractor
- B3200 tlb 149 hrs, Honda Bid Red 2013
Check my listing in the add area here on TBN, I have a BX 23 listed....
http://www.tractorbynet.com/forums/p...louisiana.html I don't know how others make the links, but you should be able to find it using this info. Thanks TroyHonda Big Red MUV
Honda Fortrax Forman 500
B3200 TLB
Land Pride 60 inch BB
Construction 4 Forks
60 inch RFM Land Pride
Land Pride RCR 1860
Land Pride RTA 1250
05-21-2011, 08:42 PM #6
- Join Date
- Nov 2004
- Posts
- 408
- Location
- Tractor
Also check out TigerfannAk's add for a B7800, http://www.tractorbynet.com/forums/p...ish-mower.html this is more what you might be looking for.
Honda Big Red MUV
B3200 TLB
Land Pride RCR 1860
Land Pride RTA 1250
05-21-2011, 10:03 PM #7
- Join Date
- Jan 2009
- Posts
- 9,126
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
What he wrote!
The machine in my sig could be great for what you want to do. And I'm retiring in Fulton soon. BUTT!! be very careful of CL ads. I've seen a lot of pictures recently of tractors in water up to their hood.
If you want a putt around the yard, construction site machine a BX will do. Once you get to where you need ground clearance, get a B.My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
05-22-2011, 01:33 PM #8
- Join Date
- May 2011
- Posts
- 27
- Location
- Olive Branch, MS
- Tractor
05-22-2011, 01:37 PM #9
- Join Date
- May 2011
- Posts
- 27
- Location
- Olive Branch, MS
- Tractor
05-22-2011, 09:57 PM #10
15 Year Old
Similar Threads
Kubota Gross HP vs Net
By Agrantina in forum Kubota Owning/OperatingReplies: 48Last Post: 01-12-2011, 09:06 AM -
Best 50 hp Kubota
By scrimshaw33 in forum Kubota Buying/PricingReplies: 23Last Post: 06-22-2010, 09:15 PM -
Want 40-50 HP tractor. Branson? Kubota?
By jfh0jfh in forum Buying/Pricing/ComparisonsReplies: 14Last Post: 09-26-2007, 09:07 PM -
Small Acreage - New Holland TC24D or Kubota BX23?
By horstuff in forum Buying/Pricing/ComparisonsReplies: 19Last Post: 03-27-2004, 11:57 PM -
Mowing RC-72 Mower Junk? Ditto Kubota Customer Service?
By M. Sullivan in forum Kubota Owning/OperatingReplies: 8Last Post: 11-02-2003, 09:08 AM
