Results 1 to 1 of 1
  1. #1
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default 2007 Rayco C140
    2007 Rayco C 140,2007 Rayco C140 with 1100hrs Great Machine for R.O.W, Brush Cutting/Land clearing work. Very productive, upgraded teeth on head to Quadco Chippers can be changed to Quadco Carbides. Machine is in great shape,has been very dependable machine. Will run 9-11hrs on single Tank of fuel averages bout 5.5-6 gallons a hour depending on what size material is being ground. The Hydraulic pump for the head puts out 69gpm @ 6000psi, producing amazing grinding capability's. Has Huge Hydraulic Oil Cooler, Two condensers for Ac unit. Also i have put a dome over the oil coolers to keep debris from pilling up, an put in two more fans for extra cooling. Best Offer!!! 251-331-4475
    Attached Thumbnails Attached Thumbnails 2007 Rayco C140-allens-house-019-jpg
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
