Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jul 2008
    Posts
    10
    Default Berlon 7ft Snow Blade
    Like new Berlon Snow Plow. Purchased in December 2008, this has seen very limited use and stored inside when not being used. I had originally bought it to use on my Case DX45 but I have upgraded to a Case 105U and its too small. Uses standard quick attach and with front remotes, you have power angle.
    From the Berlon web site:
    Made from stainless steel which prevents rusting due to scratch and wear. The Snow plow has a trip feature which, in the case of an operator accidentally hitting large objects such as rocks, the snow plow will tip and go over the object. The shock absorbers eliminate the snow plow from snapping back when it trips. The Snow Plow has a side to side tip/oscillation for snow plowing on uneven surfaces. Besides being able to tip side to side, the Snow Plow has a hydraulic angle allowing the operator to push snow to either side of the skidloader. The reversible bolt on cutting edge found on the Snow plow is made out of 3/4 x 8 steel. A rubber edge is also available for the snow plow. The snow plow shoes reduce wear on the cutting edge and minimize gravel removal while snow plowing.
    I will take some pictures in the next couple of days but I can tell you that you cant tell it from new. My email is rlong97150(at)gmail.com and my cell number is 217dash260dash9610
    $1,750.00
    Thanks
    Bob
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    New Member
    Join Date
    Jul 2008
    Posts
    10
    Default
    Plow is sold, thanks.
Similar Threads
  1. Rear Blade 7ft Arps Scraper/Grader Blade
    By dlabrie in forum Attachments
    Last Post: 07-21-2012, 07:07 PM
  2. Rear Blade 7ft kodiak back blade
    By avatar in forum Attachments
    Last Post: 03-02-2011, 11:29 AM
  3. Snow 7ft blade on BX 2360
    By Jnasystems in forum Kubota Owning/Operating
    Last Post: 02-02-2011, 07:03 PM
  4. Rear Blade 6 ft blade or 7ft
    By bearcreek paul in forum Attachments
    Last Post: 12-22-2010, 10:18 AM
  5. New M5700 4wd. with a 7ft snow blower
    By HEC in forum Kubota Buying/Pricing
    Last Post: 10-20-2005, 08:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
