Results 1 to 1 of 1
  1. #1
    New Member
    Join Date
    Oct 2011
    Posts
    3
    Kubota B2920
    Default FS Pat's Quick Attach Quick Hitch CAT1 - $135, shipping available
    $135, Shipping Available from 61733.
    These were mounted on my fathers Kubota, however, after I started converting all of the impliments to the 'standard' quick hitch dimensions, it was easier to use a true 3point hitch system. This system worked extremely well and make's working with 3pt impliments much more pleasurable as you dont have to fight with lining up the lower links and having everything aligned perfectly. These are like new - maybe used for 1-2months total, beyond that they have been sitting on the shelf. Call/Text: 309-337-0464 or PM for additional information.
    I can ship these items, they probably weigh around 7-10lbs each which would not be a problem. Shipping would be on top of the purchase price from roughly 61733.
    This 3-Point Quick Change Hitch changes your lift arms into a hook system while leaving your 3-pt. hitch flexible to use on all implements, including those that are not quick-hitch compatible. Allows attachment of heavy implements to tractor with no lifting necessary. Top link stays flexible for mowers, bushogs and other implements. U.S.A.
    Features + Benefits:
    Allows your top link to flex and float as intended for rotary cutters and finish mowers
    Attach heavy implements easily, no lifting or back strain
    Patented stabilizing system and spring-loaded latch
    Attached Thumbnails Attached Thumbnails FS Pat's Quick Attach Quick Hitch CAT1 - 5, shipping available-img_4578-jpg   FS Pat's Quick Attach Quick Hitch CAT1 - 5, shipping available-img_4580-jpg
Similar Threads
  1. Quick Hitch to Quick Attach Plate
    By lhfarm in forum Build-It Yourself
    Last Post: 01-14-2008, 01:53 PM
  2. Quick Hitches Looking for CAT1 Speeco Quick Hitch
    By jim_wilson in forum Attachments
    Last Post: 09-06-2004, 11:03 PM
  3. Skid Steer Quick Hitch or Quick Attach
    By Rolando in forum Kubota Buying/Pricing
    Last Post: 09-02-2004, 09:54 PM
  4. Quick Hitches Implement bushings for quick attach/quick hitch
    By Gary_in_Indiana in forum Attachments
    Last Post: 06-25-2003, 07:35 PM
  5. 3 pt Quick Hitch/Quick Attach
    By Rollin_M in forum Attachments
    Last Post: 06-19-2003, 08:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
