Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Oct 2011
    Posts
    25
    Baden Ontario, Canada
    JD5075
    Default Stump Grinder (Skidsteer Attachment)
    Alitec CG40 Stump Grinder (High Flow Hydraulics) mounts on Universal Skidsteer quick attach $1750.00, good working condition
    Stump Grinder (Skidteer Attachment)-t2ec16nhjhqe9nze-jp-brlhhupzmg-48_20-jpgStump Grinder (Skidteer Attachment)-kgrhqf-refekc-nhhkbrlhhwbd-48_20-jpgStump Grinder (Skidteer Attachment)-kgrhqr-lofer1mbvhgbrlhht36k-48_20-jpgStump Grinder (Skidteer Attachment)-t2ec16jhjg8e9nyfmi-cbrlhhrynzw-48_20-jpgStump Grinder (Skidteer Attachment)-alitec-specs-jpg[/FONT][/FONT]
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Stump Grinder (Skidteer Attachment)
    Are you going to power it with your tractor.
    Here is your tractor hydraulic data.
    Hydraulics:
    Type: open center
    2WD Capacity: 10 gal [37.9 L]
    4WD Capacity: 10.3 gal [39.0 L]
    Pressure: 2828 psi [195.0 bar]
    Rear valves: 1 or 2
    Mid valves: 2 (optional)
    Pump flow: 11.4 gpm [43.1 lpm]
    Total flow: 18.2 gpm [68.9 lpm]
    Steering flow: 6.8 gpm [25.7 lpm]
    Steering press.: 1958 psi [135.0 bar]
    The unit needs 25 to 30 GPM
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Member
    Join Date
    Oct 2011
    Posts
    25
    JD5075
    Default
    No I'm looking to sell it to someone with a skidsteer
  4. #4
    Member
    Join Date
    Oct 2011
    Posts
    25
    JD5075
    Default
    Didn't I post this in the proper area
    Stump grinder is for sale
Similar Threads
  1. Stump Grinder
    By reed52 in forum Attachments
    Last Post: 05-17-2011, 09:16 PM
  2. Stump Grinder
    By Toffy in forum Build-It Yourself
    Last Post: 03-26-2010, 09:12 AM
  3. 3 pt stump grinder or any stump grinder
    By kossetx in forum Attachments
    Last Post: 08-27-2006, 10:06 PM
  4. Stump Grinder
    By JohninCT in forum Build-It Yourself
    Last Post: 11-20-2004, 08:29 AM
  5. Stump grinder
    By murph372 in forum Attachments
    Last Post: 09-19-2004, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
