THIS blade weighs in at just over a ton. It can be used as a box blade or the end caps can be removed to use as a conventional blade. It has two hyd. cylinders to move the blade from side to side. These two are hooked together. Also there is a hyd. cylinder for the tail wheel. Blade is 8 ft. wide. I can send pics to an email address if I can't post them here.
Blade is in Michigan---can possibly deliver for actual costs.
Asking 2900.00
