txdon
Super Star Member
bluetc30, which automatic clorinator do you prefer?
Renob, have you bought your pool? Have you installed it? I got the pool with the slide (metal bar) wall joint, it was a PIB to install. Today, another delay, it is thundering outside AGAIN. The day time temp is up to 94 degrees so the incentive to finish is increasing. The wall is up and I will install the side supports, top rail, liner, and pump next. I built a temporary "mini deck" so I can swim while I build the composite deck with the tiger claw connectors.
