VistanTN
- Joined
- Jul 27, 2006
- Messages
- 129
- Tractor
- A-C 5020-4, Mahindra 6500 4WD, Kubota L4740 HSTC 4WD
I'd go with a wider gate than 8' -- but then my Mahindra 6500 with the wheels set widest is almost 8' and with the gate hardware, it's a squueze -- forget the baler. 10' pipe farm gates are fairly light and don't sag that much if the gate posts and the next one in line are both concreted in. If you build a matching wood gate or gates (if double) they're heavier and you might want to split it as a double with a drop rod. OK, I know, the pipe gets full of dirt -- that's why I own a couple of cheap (and I do mean CHEAP) auger bits -- the electric drill cleans the pipe out a couple of time a year.
I have about 3000' of four board rail fence. It's mostly on creosoted posts, though some of the newer posts are PT. Boards are 1x6, rough cut -- probably off the property since there is an assortment of wood. Top rail is 54" and spacing is one board width, so the bottom is about 12" off the ground.
On the stuff I dismantled and relocated to change the fence line around new shop and barn, I cut the spacing down to 7'6" so I could trim split ends off the old rail boards. You can't see the difference, but it sure saved buying a bunch of new lumber. all ours is painted black with TSC black asphalitic fence paint -- very little peeling, mostly just wears off with time.
Oh, one more thought. If you have horses (we do), don't rely on the "pass thru" time of gate latch. Board fences expand and shrink with moisture (or in our case lack of it this summer) more than those latches can accommodate. We've had to chain gate to the post on the latch side (after the horses got out while we we away! Thank God for good neighbors!).
