#41 (permalink) |
Laurencin
what log company are you using? They have the swedish cope corners down to a science., Wife and I got magazines and literature on log homes for many years hoping to get in one, We finally decided 5 years ago or so, unless some unknown happened, we would probably not get one..
__________________
"this morning I woke up with nothing to do, it is now afternoon and I have over half of it done" Digging in hard clay is easier than going fishing to a worm.. |
#42 (permalink) |
Hi, the log company is Lakeland Log and Timber Works in Northern Saskatchewan, the logs were all cut in this province, logwork was completed 230 miles North then took apart and moved to my location on trucks, most all the second floor work and ridge was cut and fitted on site during January and February, the roof is engineered trusses, 2x4 horizontal at 2 feet centeres then 7/16 sheeting, the 2x4 gives better holding for the screws securing the metal roof, most here simply screw it to the sheeting but if one checks the roofer will strip the screw. The underside of the second floor will be finished with 1x6 T&G hemlock or clear Pine. Roof will have R40 insulation between Trusses, then 6 mil Polly vapour barrier, then again 1x6 T&G Hemlock, may use a fire blocker sheetrock under, still weighing the pros and cons on the sheetrock.
The driveway is under construction today, for the last year the crews have drove across the field straight to the house, we wanted a more North road 100 yards east of the house making a final right turn in front of the garage then house, this will prevent headlights shining into the house when we have visitors, I will take a few pictures of the work tomorrow befor the gravel is placed. The garage is planned to begin next fall, like the house it will be set in the natural slope of the land, from the highway like the house appears farly small but with the full walkout its quite private, the garage will be 45 feet wide 30 feet in depth, we will be putting a pool underneath, the small door on the side of basement will connect to a glass fronted walkway to the pool area with stairs to the garage, the garage will be log construction sitting 25 feet away and scewed 15 degrees away from the house. This week befor the windows were installed in the basement I had the Kioti spreading the gravel on the floor, dug the sump pump hole with the backhoe, this weekend will be trenching the power and gass lines to the house, well digging the trenches.
__________________
Kioti CK20, FEL, Backhoe, 60" Schulte Snowblower |
#43 (permalink) | |
Elite Member
Quote:
I was more concerned with not seeing lights of traffic that was not on my driveway. Pat
__________________
Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
#44 (permalink) |
Super Member
Your home is really coming together nicely. I agree with the others that the roof system is very interesting. I'm always looking for new ideas, and that's one that I haven't seen before. Kind of a high tec version of an old idea. Very cool!!!!!
Eddie
__________________
My Goals for 2008 1. Fishing and Hunting with my kids. 2. Build my storage Shed. 3. Put my outside access bathroom together. 4. Fence in a quarter acre for Turkeys. 5. Build my gazebo for my front pasture. 6. Finish back pasture and plant it in Bermuda. 7. Start my food plots. 8. Build a comfortable deer stand for two. 9. Build a wood burning fireplace in my home. 10. New flooring in my home. 11. Build a pasture sprayer. 12. Get my old jeep running. |
#45 (permalink) | |
Gold Member
Quote:
__________________
Jerry New Holland TN75 with FEL Kubota L3430 with FEL |
#46 (permalink) |
Hi all, well the house is close to completion, we are at the interior finishing stages, the CK20 has done a fine job of the yard and driveway, we have planted lots of trees and hoping to be in by christmas, here are a few pictures last week
__________________
#48 (permalink) |
the large roof overhangs are to protect the logs from the elements, we can also use the decks when its raining, the overhangs are 8 foot.
__________________
#50 (permalink) |
Super Member
Aside from the terrain and a few minor differences, you home sure looks like mine.
You say it's close to completion, so when do you think that will be? And when will you move in?
__________________
Rob- ...The Older I get...the Better I Used to be... |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
